fiberglass reinforcement
i dont think you understand where some items are strong and where they are weak. a metal band wont do anything over the long spans across the box. it will only put pressure on the edges. try making a 3 layer strip of fiberglass as long as the longest panel in your box. see how much it bends. i had the same idea when i was starting to get into audio. ive been there, i know. keep it simple and just put in a brace. a simple dowel will do as much if not more than all that fiberglass. it doesnt have to be as complex as you think.
I agree steel bands would not work on a box.
I'm not working on a simple project.
I was just trying to find some sort of answer to my original question.
From random internet research i've found that I will be ok with the 3 thick layers I've applied.
Edited by purplesyrup
How many layers of glass would you use to reinforce 3/4 inch mdf to make it strong enough to eliminate any flex or vibration?
None. If your enclosure is flexxing that bad, you built it incorrectly. And I'm trying to decide if you use the term fiberglassing correctly or loosely...what do your three layers consist of? Too often people are pouring resin over and thinking this is somehow strengthening the enclosure. Skittles is pretty much all.over this one.
Everyone is really going around the actual question I asked. I'm purposly not telling you why i'm doing the things im doing. Opinions or guidance on box building is not needed here.
I just wanted to know the answer to the question.
My enclosure is not flexing, there is not even a sub mounted in it or a bottom on it. The reason i'm doing what i'm doing is to make this enclosure as strong as possible. My fiberglass layers consist of woven fiberglass cloth. I cut the cloth into 4 inch strips and resined around the inside enclosure horizontally slightly overlapping each other. then once set up and tacky added 4" strips vertically slightly overlapping, then another layer added horizontally,.again slightly overlapping. There was no "just pour it in there involved. And I layed the glass in the strongest pattern I found through research.
I was just trying to figure out what you guys would do to mdf to make it perform better in a high pressure situation, I want this enclosure to perform as the sub is mounted in a concrete box, its pretty much there.
No one has avoided your question. Notice the first word in my response. I get it, you know what you're doing. Good luck
This
  • Who's Online   2 Members, 0 Anonymous, 1878 Guests (See full list)
