scottam Posted May 21, 2012 Author Report Posted May 21, 2012 I just GAVE you all the external and port dimensions. STOP and use it. pretty hard to use them when the pics arent there anymore... Quote
Bump4life Posted May 21, 2012 Report Posted May 21, 2012 OP you gotta listen to these guys. They know whats up. It is better to give those subs more air then less. They need it! I would even consider giving them 5.2 net if you really want an efficient box. 72-80 inch sq of port with 14.5-16.5 in sq per cube. tune around 37 hz +- 2 hz and youll be happy. listen to us with experience and be happy. learn and go on. if you can't work torres then maybe you should study up a little more on box building because that program makes it too easy. I don't want to even think if you tried using bass box pro or any other professional program. Study up and learn then try it out. Torrres really isnt the hardest program. Quote Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
scottam Posted May 21, 2012 Author Report Posted May 21, 2012 OP you gotta listen to these guys. They know whats up. It is better to give those subs more air then less. They need it! I would even consider giving them 5.2 net if you really want an efficient box. 72-80 inch sq of port with 14.5-16.5 in sq per cube. tune around 37 hz +- 2 hz and youll be happy. listen to us with experience and be happy. learn and go on. if you can't work torres then maybe you should study up a little more on box building because that program makes it too easy. I don't want to even think if you tried using bass box pro or any other professional program. Study up and learn then try it out. Torrres really isnt the hardest program. im tryin to do everything they say then it always comes out different so i tweek and it comes out worse, and its not the program its the numbers that im gettin out of it. ha im tryin to follow along here but when i put everything in and get 61hz im gonna start playin with numbers and for 412 cvx i know he posted all the ports area and shit but links are broke so its sorta hard to work with it when i cant even see em Quote
412 CVX Posted May 21, 2012 Report Posted May 21, 2012 can you see that? If so, DO IT. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
scottam Posted May 21, 2012 Author Report Posted May 21, 2012 can you see that? If so, DO IT. thank you! i know ima pain in the ass but i WILL get this down and it shall be glourious. Quote
Guest Posted May 21, 2012 Report Posted May 21, 2012 (edited) i would finally hope so after being given 100 different designs, for free, that would work. Edited May 21, 2012 by Kranny Quote
Bump4life Posted May 21, 2012 Report Posted May 21, 2012 good luck building Quote Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
scottam Posted May 21, 2012 Author Report Posted May 21, 2012 good luck building Building won't be the issue for me. But thanks Quote
scottam Posted May 21, 2012 Author Report Posted May 21, 2012 i would finally hope so after being given 100 different designs, for free, that would work. Yep. Quote
scottam Posted May 23, 2012 Author Report Posted May 23, 2012 (edited) after this agonizing board of confusion I HAVE PROGRESS! all to spec but the port walls since there wasnt any dims for those i just did 19 back 19 across just to get an idea, the 19 length turns out to 37hz 4.6 net but its just an inch! any input. Edited May 23, 2012 by scottam Quote
