But I do agree on saving up for a better 4 channel, it'll be worth it.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
high level inputs are typically used for if you dont have rca preouts to give something a signal.
i've never seen a crossover that accepts high level preouts, and outputs the same. if you find one, that would be interesting
doubt it. typically if people are using eq's, they have the proper setup to use one
why would you need a high level out from an rca?
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
cause he wants to use an external eq with no amp
because i have no 4 channel amp. i need a way of not sending bass to my speakers
Gaahhh fucking ninja'd
Edited by Mikey Bates
why not use a set of bass blockers
cheapest solution would be bass blockers, or some type of crossover. but a 6db slope that the blockers use wont really help much
  • Who's Online   0 Members, 0 Anonymous, 3919 Guests (See full list)
