I'm tuned around 27hz and it's too low for me. I have two aero ports from precision port that I resined and fiberglassed together. What should I do to tune it higher, I'm thinking cutting the tubes and fiber glassing them back together.
Ideas?
Edited by HunterJohnson
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
whats the issue?? leave the flares duh
and cut the middle section you need to remove about 3" of each to get a rough 30 32hz tune (just going from general knowledge) i might be a inch or so of..
cut the section out and reglass ( i pvc glue my aeros together) and also removeing port length will make internal volume bigger
cut from the middle get a new connecting ring
you should not of glassed them
wow that was hard to read..i agree on the shouldnt have fiberglassed them i ALWAYS tape them together with ducttape runi t for a few days and see how i like the tune..and if needed i add or take more off, and then i glue them together
