thanks man, and as far as sensors. wher should i put them. i like the viper becuase you can buy tilt sensers, volume senors(like breaking glass) and another one i forgot. . . with that being said. where should i put them when i get one? if i only had one senser whats the best one? and i have a 99 jeep grand cherkee. . . in the amp rack? (its like a cheap movable box) with high sensitivity?
the one i linked has the sensor built in to the brain its mounted under the dash,
but it will be wired up so that if anyone pulls a door handle, bumps it hard or hits the window the alarm will go off, a soft bump sends a warning chirp.
usually it will be less sensitive in the back because its further away from the sensor but you could just have the sensitivity up but that may make it a little over sensitive on the front. some units you can add on multiple sensors.
even with my sensor under the dash though a decent bump to my trunk sets it off.
2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log
http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
  • Who's Online   0 Members, 0 Anonymous, 1591 Guests (See full list)
