I have a 1998 RS coupe thats WRX swapped. EVERYTHING was swapped from a 2002 wrx. Engine, tranny, rear end, suspension, interior, dashboard, and the gauge cluster is from an 04 wrx. I love the car, its hella fast, has a VF23 Turbo, STi 550cc Injectors, and espiler catback exhaust for now for performance, but more will come! Here are pics of my Car.
For a system, I wanted to keep it clean and simple. I used components i already had. FYI, this was my first REAL build, ive installed many systems, but this is the first one I designed and hand made everything. So if cuts arnt 100% sorry, its that im new to it, and EVERYTHING was done in my basement.
Components include:
>Pioneer FH-P5000MP headunit
>Stinger 1 Farad Capacitor, carpeted (should be 2 farad, but im only running 600 rms)
>4 gauge power, 2 gauge ground wiring
>(2) Pheonix Gold 10" Subs (forgot the model, ill check later lol) 250 wrms 4 ohm SVC each
>Hifonics BRZ1700.1D Amp - 1700@1 1200@2 600@4 (big for these 2 subs i know, but was from a different build that never was finished, and its 600 at 4 ohms at 14.4V and i know my car generaly puts out about 13.4-13.6v while running, so I figure each sub is about 25-40 RMS over powered when maxed, and the amp gain is turned down and the control knob never goes over 3/4 anyways, so id say its just a perfect amp)
Here are my 'step by step pics'
^there is a bigger fan on the opposite side pushing air in, and this one pulling air out.
I think it came out great for my first time build. Its also much louder than i expected too. The only thing id like to do is to hide those 3-4 inches of cable under the cap. I havent metered it or anything, but I was expecting just a little bump to add to the music, but it thumps pretty darn good!
in the bottom 2 finished pics, thats just dirt on the carpeting and plexi glass, not holes in the carpeting. i just snapped the pics before i cleaned it lol
Lovin the subie! If i were you I'd ditch the cap, they usually just cause more problems then they're worth.
1990 Nissan 300zx Twin Turbo - Summer Ride(No system yet, lookin to get it up to 450-500 horse first!)2006 Chevy Malibu - Daily DriverDC Level 5 15", 2 APSM-1500's, 3.88 cu. ft. tuned to 32hz1992 Honda Prelude - SOLD2 18" TC 3hp Woofers on a Crescendo BC3500.1d, 12.7 cu. ft. tuned to 35hz7r.png
ya, ive never had a ton of luck with caps. ive also never has any issues with them, and in this case, i had it laying around, and the center of my box looked naked... so the 2 met lol maybe itll give me a tiny amount of help lol
Ehh it might. How many miles are on the body/engine?
pretty cool car man, definitely something you dont see every day i am a huge fan of the rs coupe.
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
as far as i know, rougly 210k on body, and 110k on everything else
thanks tebo. ive never dynoed it, but with all the mods done, it has rougly 290 AWHP (depending on the boost)
