Amp all 4 speakers on a 4 channel amp and since you're running all Kenwood look for a Kenwood Amp you should be straight with a 100x4 amp just go really easy on the gains for the front speakers.
This Kenwood amp will give your by 9's full power but you will have to be really gentle on the gains for the 5 1/4's http://www.sonicelec...elon-XR-4S.html
Price of your guess is direct out of the worehouse. And it´s a class D amp, for mids and high´s class AB sounds better.
I guess you http://www.ebay.com/...=item43afddbb14 very good SQ amp, or the bigger brother http://www.ebay.com/...=item1e5dae1ba5
The reason I suggested the amp I did was because he is running all Kenwood gear and it would make more sense to keep matching gear than change it up now. The soundstream reference would be dope but I am a stickler for matching my gear and I do that as much as I can.
yeah, thats what I'd like to keep going for. Until I get to the subs that is. I'll prolly even upgrade to a eXcelon headunit.
Have you already started thinking about subs?
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
I've started slightly, I've had my fair share of simple setups and I think I'd like to go big now. I do have an idea of turning my trunk to the whole box, and inverting the speakers in place of where the back seat would be, I'd love to get 2 AA SMD's simply because astetically they'd look beast like that and they bang hard anyway.
Ifnot, I plan to go the DC route, with at least 2 lvl 4 XL's or better.
the one issue i got tho is the back wall behind the rear seat is just cluttered with fuse boxes & a bunch of crap from the bose system.
this post on this caddy forum should help elaborate on my troubles thus far and upcoming.
http://www.cadillacforums.com/forums/cadillac-audio-video-security-systems/211854-installed-oem-hu-now-no-sound.html#post2422667
97 Cadillac Eldorado ETC
Current Setup:
~Kenwood DDX318 (HeadUnit)
~Kenwood eXcelon KFC-X133 (5-1/4" Doors)
~Kenwood eXcelon KFC-X693 (6"x9" Rear Deck)
Coming Soon:
Kenwood eXcelon KFC-X1730P (6.5" Doors w/ 1" Swivel Tweeter)
Kenwood eXcelon XR-4S (400.4 Amp)
Than look for a Kenwood class AB 4 channel (maby a used older one). Even high/er quality Class D amps sound´s thin and together but very on the point. Good class AB sound´s fat, warm and wide.
"in the abundance of water, the fool is thirsty" Bob Marley
Okay I can see your issue. can you just uninstall all of the bose stuff since you are aftermarket or is it integrated in the system and will cause issues? If anything hit up snafu on here he is an electrical genius so he may have a solution for you to bypass the issue. I can't check out the link you posted until I get to work. I am mobile now.
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
I kno the bose crap is tied into the anti-theft system & i read stories of the car randomly cutting out and refusing to start. I plan to pull it all out over the weekend tho.
as far as the other stuff also mounted behind the rear seat... i got a fuse box and a few other things i have yet to learn what they are. Thinkin i'ma have to pickup the service manual so i can learn what i can rip out.
also, still been havin issues with the new head unit retaining memory after its powered off. its wired to the 12v constant but i still think the bose brain box is messing with it so i'ma be running a 12v directly off the battery w/ a fuse. hopefully that solves that issue.
basically it comes down to having to rewire the car like it never had a audio system installed.
Current Setup:
Coming Soon:
if you want a cheaper option look at the mb quart onyx series. a lot of people run then due to the power / price ratio
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
You could always get a custom built fuse box and wire it like that.
2013 Dodge Charger
Build Log
Build Log
Build Log
My Selling Feedback
