Can you do me one more design?
Same sub 1.5 cu ft ported tuned to 28hz
I modified the design above to 1.5 cubes at 33Hz, I modeled the sub and 28Hz will reduce the output a lot. I would even tune higher.
You can use the Torres calculator to verify the results if you want to. Port centerline length is 30 inches.
Well you think 33HZ is too low at that size? This is the first box I'll be building and just want it to be punchy but also hit lows on some hip hop songs that I also listen too, so I guess I'm just more concerned about damnaging my sub with the bigger box size or it being too boomy. All I know is right now it sounds like SHIT in the sealed box I have as its 16x16x16 which is way bigger than the recommended .75-1.0 sealed. So yeah I'd like dimensions for a 1.25cu box at maybe 35-38HZ unless you think 33HZ is ok.
  • Who's Online   0 Members, 0 Anonymous, 1545 Guests (See full list)
