sub directions? all up or sides ? box help!
8- sundown 8s, v2s. each need 0.5 of space.
1- ns1..
how does this look !?
12"x26"x36" with 3/4s thick wood. = 5.13 interior volume. with port and sub displacement thats 4.03 cubes,
if i measure the tuning with 2 20" 6" aero ports, im at 35hz but thats before displacement if i measure after all displacement im at 40hz... is it after or before ?
also the 2 6" aeros can be cut if need be...
got all the equipment and wood ready to go... just need a good design !!
who's good at designs sketch up and cut-up sheets blueprints, ill pay a few bux.
Edited by __d_a_v_i_d__
well i said 2 6 just on cone area but its only 4 cubes i would do the 1 6 inch port then try 2 or vice versus
its the cone area of 2 15's and roughly a 10
if your gonna build an 8 inch areo i would roll with that IMO
Edited by Team Bassick (ALPINE)
Idd build 4.8net with 2x6" aeros at 32-33hz
You may even want a single 8
I think the problem you will have with aero ports is you will have to bend them, witch is no big deal if use plumbing pipe
Edited by john253a
I'M on my phone ao I can't do it at the moment, but some els may be able to
In the stickys in the section download torres and it will do it all for you
Allow 0.1 for sa8v2 and 0.8 for v1.5
For 8 of these idd brace the shit out of the box and maybe even use 1" to build the box
Idd tune it a bit lower then 34 unless you like a peeky box 32-33 seems to be the best for theis. Unless you no the peek of you car and use that to your advantage,
  • Who's Online   1 Member, 0 Anonymous, 846 Guests (See full list)
