wmrcs Posted May 25, 2012 Report Posted May 25, 2012 Would I be able to add another ported enclosure to my current enclosure and be able to make a successful 6th order if the second chamber I add is right? I don't want to build a huge ass 6th order if I can't use part of my current ported box. E34 540iT/6
Hugh G. Rection Posted May 25, 2012 Report Posted May 25, 2012 its a little more complicated than that to say the least....... Owner of BigAss Ports
wmrcs Posted May 25, 2012 Author Report Posted May 25, 2012 its a little more complicated than that to say the least....... Okay well can you say more than the least so I have an idea? Not a whole lot of box knowledge over here.. E34 540iT/6
Hugh G. Rection Posted May 25, 2012 Report Posted May 25, 2012 its a little more complicated than that to say the least....... Okay well can you say more than the least so I have an idea? Not a whole lot of box knowledge over here.. you cant just add onto a ported box you already have because in a bandpass you have both sides of the sub loaded. it operates an entirely different way. in a standard ported configuration only the rear of the sub is loaded,, as in a bandpass the front and rear are both loaded. Owner of BigAss Ports
wmrcs Posted May 25, 2012 Author Report Posted May 25, 2012 its a little more complicated than that to say the least....... Okay well can you say more than the least so I have an idea? Not a whole lot of box knowledge over here.. you cant just add onto a ported box you already have because in a bandpass you have both sides of the sub loaded. it operates an entirely different way. in a standard ported configuration only the rear of the sub is loaded,, as in a bandpass the front and rear are both loaded. Okay well I know that. Help me see why I can't just build practically another enclosure and attach it to my box if the sub and port were facing the same way. E34 540iT/6
