Going to yes. I don't have the car here yet. I am just wondering if I will get big voltage drops and if I will have to charge the battery very often
I'm not exactly sure the specs on the battery but I recently burned up my stock 90A alt big three and xp975 in back. Although it could have been on its way out as y charging voltage was 13.6 but regardless you'll need to charge up the battery's often with that little alt and the pull your amps asking for.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
Thanks for your answer:)
Here are the specs of Odyssey PC1500
PC 1500 MS Design:
  • Absorbed glass mat (AGM) technology
  • 12V pure lead VRLA
  • SAE Group 34 footprint
  • Rugged construction
  • SAE terminal and 3/8" stud (pos.) 5/16" stud (neg.)
  • Can be mounted in any orientation
  • Lifting handle
  • US DOT and IATA certified non-spillable
  • Shipped fully charged
  • Container and cover made from oil resistant plastic
Performance features:
  • PHCA: 1,500 at 80°F (27°C)
  • CCA: 880A at 0°F (-18°C)
  • CA/MCA: 1,050 at 32°F (0°C)
  • HCA: 1,250A at 80°F (27°C)
  • Reserve capacity: 135 minutes
  • Short circuit current: 3,100A
  • Deep cycling capability: 400 at 80% DOD
  • Design life: 12 years
  • Typical service life: 6 to 8 years
  • Operation temperature range: -40°F
    (-40°C) to 176°F (80°C)
High rate discharge:
1,500 amps for 5 seconds
1,280 amps for 10 seconds
1,170 amps for 15 seconds
1,100 amps for 20 seconds
Weight: 49 pounds
PC 1500 MS Design:
  • Lifting handle
Weight: 49 pounds
Not a problem that's just my experience with it, I'm not very knowledgeable in the battery department man might wanna wait for someone that can further help you.
Well thank you for your time and explenation. I may actually have more space under the hood to get a bigger version of the series :D We'll see when the time brings.
Anytime, if your going to get another battery I would suggest xs power the price is a tad more I'm sure but they have been tested against many other batteries to be the best.
I will get Odyssey for cheaper + discount where I am from :P
Get the group 31 version and you will be fine. And to the other comment above xs power isn't the best, they are one of the better battery brands but there are too many factors to consider to say they are the best.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
  • Who's Online   0 Members, 0 Anonymous, 1115 Guests (See full list)
