Wiring an Aftermarket Headunit, SOLVED (with a factory amp)
your factory amp has the wiring schematic on it, just like the radio does. i retained onstar so i modified an OS4, the LAN connection isnt the same as a regular GM so it required some troubleshooting to get it to work
SMD SuperSeller VerifiedJbondoXJames Shields
Solved BTW, easier than i thought it would be, but now i have some random distortion had volumes above halfway. I made a post about it in mids and highs.
I think i pinched a wire somehow because it happened on a cold start after i shoved a box in my trunk.
Its not the After market HU or the wire harness going into it.
I tested the stock one and the same thing happened.
I can fade it to the front and it goes away, so it must be something to do with the rear.
This is what happens when you use a factory amp and speakers...
lol,glad you figured it out.But you still want to use the factory amp.
2009 bmw 5 series
Head Unit Stock
Amplifier-JL Audio JX 360/4
Processor- Audiocontrol LC6
so when i faded to the rear and the right at the same time. the speaker sounds like ass.
disconnected it, and i can fade to the rear with no distortion. Weird how one speaker made the 6 other ones distort?
anyways, i can listen to it now full tilt =]
  • Who's Online   1 Member, 0 Anonymous, 1794 Guests (See full list)
