Strapping problems
jeffrm
I tried strapping my amps the other day and I had them wired up correctly, but my subs were making a very high pitch noise and when I turned it up they both went into protect. What could be my problem? Could it be too low of ohm load? ( 2 dual 4s wired parallel seperatly) should I try series?
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
What amps do you have and did you follow the manuals instructions closely. there should be a switch for one to be slave and one to be master.. have you switched those. Either that or depending on the company you may need a strapping cable.
NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! TEAMHIGHX-CURSIONsig-1.jpg
Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
Rd 1750.1 v1 its not the kind with the master slave switch its the kind with the bridge in/out rca. Im strapping the rd 1750 with an atomic 1600 only because its what I have. I also already contacted atomic and these amps have the same exact board ( which I checked) and he said they are linkable together with no problem
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
This is how they were done
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
http://www.rdaudio.n...anual_final.pdf Looks like you got it correct check your load with a ohm meter. here's the manual for your amplifier. observe page 6 for Rca wiring.
OHHH I just read your using different amps.... Don't go by what one company says.. you need the head nod from them both! I wouldn't do that with 2 different amps. Check to see if there defective now and if either are I'd talk again to the guy who told you yes it's fine and get him to give you a new set that will strap on the house!
See thats the thing rd and atomic were built out of the same build house for some time along with sundown and a few others. Ive checked the boards and they have the same numbers for parts, same resistors, and all. The only noticable difference was the sleeving on the 8 gauge wire inside. 1 was clear and the other had black.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
somethings different. verify they both still work properly.
I know the rd does its still bangin in my truck. Ill have to check the atomic tomorrow. I think it was just too low of an ohm load. They were seeing .5 each. It may work correctly if I series the subs then parallel to amps.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
  • Who's Online   0 Members, 0 Anonymous, 952 Guests (See full list)
