2 AQ HDC3 18's in my 99 Tahoe **LOT'S OF PICS**
My box is single layer birch with a double flush baffle..and all thred top to bottom side to side..I push 17k to it with 4 18s zero flex
So in my case where would you put it?
~Team Nussiance~
Head Unit: Sony MEX-BT38UW
Amplifier: 1 AQ2200d for break in period
Subwoofers: 2 AQ HDC3 18's
Mids and Highs: 1 pair of AQ PA-6.5's and 1 pair of AQ PA Supertweets
Scores: 148.1db @47hz
146db- Dash
143.8db- Headrest
Both on music
Sideways few inches from port from side to side..if top flexes then one top to bottom.. you have the port sides that will give you added support so most flex will be on sides
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
So inbetween the V and the port. Pretty much do + with all thread?
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
Hooked her up last night as is, no bracing and only 1 baffle. Wired them at 1 ohm and man...... This shit bangs. Definately the loudest system i've had! Played around with it for about 2 hours. Subs weren't even warm to the touch. Didn't play much low stuff but I did play Dorrough- Trunk Bang and the lows in that made my barn doors flap!! The subs are barely moving at all! Can't wait for these STIFF bitches to loosen up and kill the lows!!!!
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
Good lookin box bro. I ain't gonna use ur same box dimensions but could u pm them to me so I can get a idea of what ie (port length and width at back and front) I'm lookin at I'm thinkin bout doin 2 18s in my 97 hoe. But I'm pretty sure my measurements are close to yours except height a little. If not its kool bro. And deff use allthread wit floor stands to push on the box
whats wrong with fat chicks? they are like mopeds, as long as your friends dont see you riding it, they are a blast! hahah
I am dumb as a stump. I live in the south and we are all dumb here.
yeah thats what he means im like 99% sure..also if you plan to meter take ur sander (or router) and round off the edge of the back of the ports..usually good for a tenth or 2 on the meter..and glad it sounds good bro :good: aq hd's are fo sure some good woofers
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Round over inside edges of port or use 11/2 pvc and cut 3/4 slot out of midddle an slide it over port edges on each side it will help airflow into port...post some vids
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Thanks man. And PM sent!!
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
Definitely plan on getting a good round over bit for the port! And I'm loving the AQ's!!
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
I work during the day so the 1st chance I get with some daylight I will definitely post some vids on my channel!! And I think I will use the pvc idea because it would be hard as hell to stick my router in the port to round it over lol!!
~Team Nussiance~
146db- Dash
143.8db- Headrest
Both on music
