XS Power
yea? so can you use the 2 together as long as they both are at a good resting voltage?
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
hey yo anyone else have input?
BMW M340 xDrive
agm's have a higher resting voltage than standard wet cells. so they would constantly be fighting with each other trying to balance out the voltage. so essentially the wet cells would get charged and the agm's would get discharged, while at rest afaik.
so dont mix at all? under no circumstances?
BMW M340 xDrive
i dont know. people say dont mix, yet other people do. i'm only running a duracrap under the hood so i cant speak from experience.
I've never heard or seen anyone say it was OK...
My question was if it would be OK for under a week
My d925 is coming Monday so I held off....
I would recommend not mixing any batteries (brand/technology)
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
if you are worried about the battery beign by the radiator, then I would either get the metal case for the battery, or go to your local auto parts store (autozone, pepboys, or where ever) and purchase a heat shield wrap for the battery. They are pretty cheap (under $20) and can save your investment on the battery. One of the guys here has had his 975 under the hood in his car for 6 years now with no problems, but if the radiator is right on top of the battery it can cause a build up of heat.
