lotus Posted May 30, 2012 Report Share Posted May 30, 2012 (2 12s) my box is 15high x 32.5wide x 25deep. (25 deep with baffle over subs) the port length is 21.5inches all together and the box has 2 1inch dowels crossed for bracing. port is 13.5 x 4.5 and i believe tuned to 36.33hz, i built a port extension (9inch) what will this make my tuning? and how much of an extension do i need to tune my box down to 32hz? Quote 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH Link to comment Share on other sites More sharing options...
tejarillo Posted May 30, 2012 Report Share Posted May 30, 2012 Can you defined or describe the "port extension" is it the same width and height? Quote Link to comment Share on other sites More sharing options...
mttornquist Posted May 30, 2012 Report Share Posted May 30, 2012 I think I understand what your saying. You go from this: To this: After sub displacement that should put you at just under 32Hz assuming your port extension is 13 x 4.5 as well. Wait for a second opinion though, I may be wrong on that. Quote My Build Log: http://www.stevemead...lmost-complete/ Link to comment Share on other sites More sharing options...
Joe X Posted May 30, 2012 Report Share Posted May 30, 2012 Just fill the missing boxes with the correct values to get a final answer. Quote Link to comment Share on other sites More sharing options...
lotus Posted May 30, 2012 Author Report Share Posted May 30, 2012 y would it be 30.5? it says inner dimensions so doesn't that still make it 21.5? and its 3 common walls and .28 woofer displacement with 1 baffle Quote 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH Link to comment Share on other sites More sharing options...
mttornquist Posted May 31, 2012 Report Share Posted May 31, 2012 (edited) y would it be 30.5? it says inner dimensions so doesn't that still make it 21.5? and its 3 common walls and .28 woofer displacement with 1 baffle because you are adding a 9 inch extension. 21.5+9= 30.5 Then you see I added 9 to the length of external port? that shows the calculator that those extra 9 inches will not be inside the box therefore they will not be subtracted from the net volume. EDIT: Your final tuning will be 30.95Hz if you add that 9" extension. Edited May 31, 2012 by mttornquist Quote My Build Log: http://www.stevemead...lmost-complete/ Link to comment Share on other sites More sharing options...
lotus Posted May 31, 2012 Author Report Share Posted May 31, 2012 y would it be 30.5? it says inner dimensions so doesn't that still make it 21.5? and its 3 common walls and .28 woofer displacement with 1 baffle because you are adding a 9 inch extension. 21.5+9= 30.5 Then you see I added 9 to the length of external port? that shows the calculator that those extra 9 inches will not be inside the box therefore they will not be subtracted from the net volume. EDIT: Your final tuning will be 30.95Hz if you add that 9" extension. dont you mean the final tuning will be 31.34hz with 30.5 port length. and thanks i was worried that i would only be tuned to 34.95hz with the extra 9 inches Quote 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH Link to comment Share on other sites More sharing options...
lotus Posted May 31, 2012 Author Report Share Posted May 31, 2012 i mean 31.88hz with displacements Quote 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH Link to comment Share on other sites More sharing options...
mttornquist Posted May 31, 2012 Report Share Posted May 31, 2012 no i meant 30.95 Hz. That's what I came up with after I added up all the displacements for real, your dowels go the 32.5 inch way right? Quote My Build Log: http://www.stevemead...lmost-complete/ Link to comment Share on other sites More sharing options...
lotus Posted May 31, 2012 Author Report Share Posted May 31, 2012 no i meant 30.95 Hz. That's what I came up with after I added up all the displacements for real, your dowels go the 32.5 inch way right? yeah there cylinders, one top to bottom (13.5 inches) and the other side to side from port wall to box wall (25.75) no dowel in port and there both 1inch thick Quote 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH Link to comment Share on other sites More sharing options...
