Audio4Lyfe Posted May 31, 2012 Report Posted May 31, 2012 Hi guys, im looking for a distribution block an have been seeing some with fuses and some without fuses. My question is do i need a distribution block with a fuse? An what is the point with the ones with the fuses? I will be running two amps and im running 1/0 gauge tsunami amp kit. Thanks for any help!!!
bass_stalker Posted May 31, 2012 Report Posted May 31, 2012 to be more protective of amps with board mounted fusing, to give you a way to fuse amps that need external fuses. and lastly to fuse the run of power wire so you dont overload it JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
White Lightning Posted May 31, 2012 Report Posted May 31, 2012 My suggestion would be to get the ones (positive and ground) with fuses to be on the safe side ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
