here is the port
porting through rear deck
My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/
2001 Ford Mustang GT
4.6 SOHC 380HP
270 amp Mechman alt
2 12" Treo SSX custom built.
6.47 cu ft, tuned to 32Hz
2 hifonics Brutus 2400.1, strapped
1 optima yellow top
1 Kinetic HC1800
14.4v @ 29Hz, 2k RPM
over 100ft 1/0 XS flex wire
Big 3 in 1/0
100sq ft fatmat deadener
145.3 on music, 142.6 sealed on music
Stop being a pussy and wall it off.
I hate when my google breaks too
I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
the cut pieace of metal from rear deck
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
Looks like I get the car back Tuesday from the shop that's building my box. Ill have some pics of there after install when I get it back.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
  • 10 months later...
well this is long over due for a update. just been busy with college , wife and kiddo. that and bumpin the shit of my system.
so here is some more pics. it is done minus mids and highs which will come this coming winter!
here is the box after being built and resined.
396796_10151889370005093_1972921888_n_zp
395999_10151889356685093_472362801_n_zps
1/0 being ran. second battery is behind the passenger seat.
428786_10151889357450093_459998757_n_zps
165899_10151889362135093_552775414_n_zps
303594_10151889356245093_355154518_n_zps
306602_10151889361580093_548914484_n_zps
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
1/0 under the car, zip tied up out of the way. 2 runs of pos and neg from front battery to second battery
392937_10151889365635093_1262280030_n_zp
532128_10151889364980093_480634869_n_zps
final run of 1/0 under the hood and ready to be trimmed
524018_10151889361870093_528656378_n_zps
all 1/0 is soldered. over 30 1/0 soldering connections made
534856_10151889368170093_1894991767_n_zp
checking for voltage lose.
540797_10151889371170093_1713555845_n_zp
test fit on the second battery. i used expandable foam to hold the battery still in the battery box since it liked to slide around
539595_10151889368505093_1415586100_n_zp
310023_10151889364575093_546850788_n_zps
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
i made my own buss bar. 1/8 steel plate. edges grinded down so they dont cut the wire jacket. these will be replaced this coming winter with alum buss bars
391432_10151889368835093_1806030703_n_zp
made a fuse bracket that bolts to the power steering fluid resivor. painted it yellow to match the car. holds the 2 fuse holders for the 2 pos runs from front batt to second batt. and the 3rd one is for the alt.
548595_10151889371465093_787778965_n_zps
here is the amps. i have one on a rack i made on the side and the other amp is mounted on the sub box with rubber isolaters
553155_10151889360350093_2016042605_n_zp
574760_10151889370890093_1206818962_n_zp
553674_10151889360005093_918979225_n_zps
checking the Ohm load of the subs with some scrap wire
552295_10151889366645093_211513877_n_zps
560881_10151889366390093_119738057_n_zps
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
if your wondering about the subs, they are 12 inch treo SSX subs. grossly under rated at 2000 watts RMS.
8051_10151889366125093_2066136643_n_zps8
ran the port through the rear deck. port measures out at 7 1/2 x 7 1/2 (outside specs)
282732_10151889357080093_2670315_n_zps8c
i made a cover to go under the rear deck lid cause i didnt like how it looked. i also resin'd the underside of the deck lid cover so it wasnt such a pieace of shit.. i'll be making a new custom one soon out of plywood. the cover also helps seal off the trunk. under the cover is alot of expandable foam
394198_10152832470010093_1079230887_n_zp
here it is all done before i sealed off the trunk.
528365_10152776217670093_1290396625_n_zp
532772_10152776217960093_1028311973_n_zp
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
here is the boxed sealed off from the trunk.. i have some cleaning up to do and i'll be replacing the bottem carpet since i got some foam on it. i made a cardboard backing to fit in and foamed over it. the applyed fiberglass resin over the foam to seal it off.
942155_10152832469725093_1131376909_n_zp
923443_10152832469705093_1157825400_n_zp
Edited by boostin302
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
everything up under the hood in place where it should be.
253345_10152832470115093_1998724862_n_zp
for now i am running a stock alt with the 2 optima yellow tops. at idle i have voltage drops but driving around, its nowhere bad. i usually stay at 13.6 volts. i give all demos at 2k RPM and just enjoy my system.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
I cannot lie I miss my mustang
Your system looks pretty awesome so far
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
