Dillan Turvold Posted June 1, 2012 Report Share Posted June 1, 2012 (edited) The box I have is 15x32x20, 2 separate chambers, each w/ a pvc port 3" x 8 1/2", tuned @ 30hz -2.1 cu. ft. per chamber~ It's peaking out really low.. I'd say around 34hz, it drowns out the mid-bass almost completely. I'm relatively new to box designing, and I don't really know much about how a design affects the sound quality... I tuned it to 30hz to hit the lows really nicely ( which it does ), but I'm missing the midbass, should I just cut the pvc shorter to raise the tuning or will that not really make much of a difference? Is there possible to little of port area? Subs- 2 kenwood 12"s, 4ohm @ 400wrms, 2 cu. ft. recommended per chamber, running on a kenwood 1800w d-mono amp. ( 900w rms ) I'm running the subs parallel on 2 ohm @ 450wrms a piece (not benched so I don't know the exact wattage) Edited June 1, 2012 by Dillan Turvold Quote Link to comment Share on other sites More sharing options...
will77530 Posted June 1, 2012 Report Share Posted June 1, 2012 shortening your ports will bring up your tuning Quote Link to comment Share on other sites More sharing options...
b-dubs89 Posted June 1, 2012 Report Share Posted June 1, 2012 i am in the same boat as you with learning about box design , there are many people on smd that will tell you a ported box with good design and tuning can sound awsome , but every ported box i have built has been peaky somewhere through out the range and i didn't much like any of my ported boxes i have built as opposed to a sealed box for the same woofer . the link i added is for a port calulator i had found a while back not to sure how right on this is but it is fun to play with http://www.mobileinformationlabs.com/HowTo-1Woofer-Box-CAL%20Port%20lenth%201.htm Quote Link to comment Share on other sites More sharing options...
Dillan Turvold Posted June 2, 2012 Author Report Share Posted June 2, 2012 shortening your ports will bring up your tuning yes I mentioned that in my post.. but will that help the peaking being so low, and bring back the mid-bass? Quote Link to comment Share on other sites More sharing options...
b-dubs89 Posted June 2, 2012 Report Share Posted June 2, 2012 if your set up is smashing the lows pretty well , maybe getting some midbass drivers would be a better solution to your problem , i have had some alpine type r's and a rockford t1 15" and they both smashed the lows but had no midbass really . Quote Link to comment Share on other sites More sharing options...
b-dubs89 Posted June 2, 2012 Report Share Posted June 2, 2012 heres the $9 focal midbass for you http://www.parts-express.com/pe/showdetl.cfm?Partnumber=299-155 Quote Link to comment Share on other sites More sharing options...
skittlesRgood Posted June 2, 2012 Report Share Posted June 2, 2012 (edited) your port is way too small. and i mean WAAAYYY too small. what do you have for midbass? usually people go with heavy sub stages dont care about midbass and its pretty well always drowned out. i mean, a 6.5" speaker isnt going to keep up with a 12" speaker on 5x the power. just not going to happen. you would either need to install 8"s, or get a nice pair of 6.5" midbass drivers if you want any shot at hearing them over the subs. VV ninja'd! Edited June 2, 2012 by skittlesRgood Quote If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people. Link to comment Share on other sites More sharing options...
Guest Posted June 2, 2012 Report Share Posted June 2, 2012 its peaky probably because the ports are way small. Quote Link to comment Share on other sites More sharing options...
Dillan Turvold Posted June 2, 2012 Author Report Share Posted June 2, 2012 I was thinkin abour makin a box w/ 1 12, 2 8" mids and having them all in seperate chambers ofc, 8" mids need boxes right? Quote Link to comment Share on other sites More sharing options...
Guest Posted June 2, 2012 Report Share Posted June 2, 2012 I was thinkin abour makin a box w/ 1 12, 2 8" mids and having them all in seperate chambers ofc, 8" mids need boxes right? why do you want to do this? Quote Link to comment Share on other sites More sharing options...
