Enclosure design help
Hello, I'm going to help a buddy build a box and wanted to see what you guys would recommend or what design you could come up with because i don't know if i should go slot port or go with what pioneer recommends which is a round port (3" X 3.5").
The sub is a pioneer TS-W3002D2 12"
Ideal ported recommendation- 1.2Cft
Car's max dimensions - H=16 D=20 W=30
Any help appreciated, Thanks!
Ok here is a suggestion for 3002 good for trunk/hatchback vehicles, port/sub front or back firing:
Enclosure Specifications:
Fb = 34 Hz
Vb = 1.5 ft^3
External Height = 15 in
External Width = 27 in
External Depth = 13 in
Port Width = 1 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 27 x 15
Left & Right Sides = 11 1/2 x 13 1/2
Top & Bottom = 27 x 11 1/2
L Port Internal Assembly Parts:
Front to Back = 9 3/4 x 13 1/2
Extension = 18 x 13 1/2
If you want something different or have any questions let me know.
Thanks a lot Joe X! Now idk if you guys carpet your enclosures at all but, if i carpet it would i just make the front back top and bottom sides an inch longer so i can tuck the fabric in then staple it?
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
