Amart88 Posted June 2, 2012 Report Posted June 2, 2012 Ok, so I had my 2 BC3500's strapped Series/paralell and I just finished rewiring them to each woofer in paralell. I was talking too HHRed and he said something about you can still use slave mode to match gains when the amps are seperate. I can;t remember how he said to hook them up. If i use the Strapping output or just the normal RCA out or both. I'm not sure. Also I would like to use one remote knob for both amps. Will slave mode still work for that? or can I use a splitter.? Thanks My 2005 s10 blazer build. 4 zcon 18's walled.
cosmo10292 Posted June 2, 2012 Report Posted June 2, 2012 It has a strapping output? then yes! just strap the slave to the master and the master will control the slave with all gains! wire the bass remote to the master amp and it will also control the bass on both amps
Amart88 Posted June 2, 2012 Author Report Posted June 2, 2012 It has a strapping output? then yes! just strap the slave to the master and the master will control the slave with all gains! wire the bass remote to the master amp and it will also control the bass on both amps So it don't matter which way they are wired as long as its 2 ohm final load? ima go look at the manual but damn I just spent all day doing this so its F*kin' staying this way. I thought it would only work with both amps negitives connected until ed told me otherwise but I don't know how it work the other way. My 2005 s10 blazer build. 4 zcon 18's walled.
