K well I converted my subs to direct leads because the metal ring terminals would get so hot they would melt off of the plastic mounts. I have my subs at the moment each wired in series then from one coil of each straight to the amp. I blew a sub, and want to wire only one sub. My question is, if I want to go parallel, is it fine if I just run both neg leads off the sub, to the neg terminal on the amp, and same for pos. Or do I need to wire one neg to the other, and from there to the amp. Just curious so I don't accidenlty blow my new amp, and because having to solder a wire onto the tinsel lead wont be fun, nor do I think will it work well either.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
It's the same thing. So yea you can do that.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
if its the amp in ur sig then pos to pos and neg to neg will be fine depending on ohm load of the speaker, ie wireing in parallel lowers ohm load
and might have to do some adjusting on gain for other sub so not to blow it
hope this helps
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
That's what I was looking for, and yes I will be dropping from 4 ohms to 2 ohms. The amp is was tuned at 33V which I got from 300 watts * 4 ohms then the square root of that. running at 2 ohms it will be running actually at the exact same voltage. 300W * 4 ohms is the same as 600W * 2 ohms haha
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 1068 Guests (See full list)
