ALPINE408 Posted June 6, 2012 Report Share Posted June 6, 2012 Cause you can forget to turn them off burning up your fans or killing your batt also do not just hook them up to power and ground off your amp they will never turn off that way ether Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
White Lightning Posted June 6, 2012 Report Share Posted June 6, 2012 (edited) Sone electronics stores sells the "Wireless remotes" kits you can wire into you relay to turn on and off objects ... From your remote, I would suggest running to 2 relays ... one for your amps and one for fans and LED lights ... and you do not necessarilly have to run fans and LEDs off of your remote wire ... if you plan to run a switch up to your dash, the no need to go to the remote wire ... just come off of your auxillary fuse ports to a switch, then to your relay, then to your objects ... Edited June 6, 2012 by Cablguy184 Quote Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch Link to comment Share on other sites More sharing options...
