Cause you can forget to turn them off burning up your fans or killing your batt
also do not just hook them up to power and ground off your amp they will never turn off that way ether
Sone electronics stores sells the "Wireless remotes" kits you can wire into you relay to turn on and off objects ... From your remote, I would suggest running to 2 relays ...
one for your amps and one for fans and LED lights ...
and you do not necessarilly have to run fans and LEDs off of your remote wire ... if you plan to run a switch up to your dash, the no need to go to the remote wire ... just come off of your auxillary fuse ports to a switch, then to your relay, then to your objects ...
Edited by Cablguy184
