Lucky4Designs Posted June 4, 2012 Report Posted June 4, 2012 So I've been thinking of some other options in my Corolla. I started out wanting to replace the back seat with a giant box and run four 15's, but decided I'm not going to have enough airspace and it's going to be way too expensive (keep in mind this is a budget build!). A friend of mine dropped off a sheet of wood she had leftover from a project, so I decided to break out the ole' jigsaw and make some cutouts for a mock-up of what a full-scale wall would look like in my Corolla, and I LOVE it. What do you guys think? Two 18's walled and tuned low, I will be building the subs as well I plan on running about 4kW RMS on the substage, and around 1kW on everything else. 2001 Toyota Corolla CE: 4x Crescendo PWX6.5's 2x Crescendo FT1-SE's 1x DC Audio lvl 2 M1 8 (looking for more) Slot port box 0.7ft^3 @ 31.77hz Rockford Fosgate R750.1 1/0 Knu wiring all around Looking for XS Power D1200
mattc3366 Posted June 5, 2012 Report Posted June 5, 2012 Looks like a plan! I say go for it should be pretty dam loud in that size of a car. subwoofers - two eclipse 88120s box - 3.4 cubes tuned to 32 hz amps - aq1200 and pheonix gold zx450 New build : 2 obsidian audio 15s same amp 6.1 cubic foot box tuned to 32 hz in a civic hatch
Lucky4Designs Posted June 5, 2012 Author Report Posted June 5, 2012 Now I'm no Sketchup master, but I built this box based off of my calculations from the RE Audio Box Calculator. While I haven't built the subs yet, this is just a "rough draft", if you will, of what I can work with in the vehicle. At exactly 10.0 ft^3 of airspace (all displacements accounted for), I can fit the two 18's in there with a tune of 31.77hz, about perfect for what I'm looking for. Let me know what you think! This is the new, updated build! (Will transfer this over to correct forums when it's underway). 2001 Toyota Corolla CE: 4x Crescendo PWX6.5's 2x Crescendo FT1-SE's 1x DC Audio lvl 2 M1 8 (looking for more) Slot port box 0.7ft^3 @ 31.77hz Rockford Fosgate R750.1 1/0 Knu wiring all around Looking for XS Power D1200
Riley Evan Houser Posted June 5, 2012 Report Posted June 5, 2012 Nice man, if you're gonna do something to this extent make sure you do everything the right way.. Don't get in a hurry..be patient and enjoy everything. I'm sure it will be sick when you get done
