Give us a budget.
What voice coils do your subs have?
they are 4 ohms would that make it less powerful?
not the least bit. we just ask so we can recommend amplifiers that will be able to give your subs the best amount of power. the only reason subs come in, for example, dual 4 and dual 2 models, is just so that you can get a desired ohm load with whatever amp that can do X watts at X ohm load
Edited by Kranny
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
Here is the wiring configuration and ohm's law. you will be running two 4 ohm dvc subs in paralell or series. (1 or 4 ohm) Those brutus amps put out between 1200-1500 watts @ 1 ohm depending on which model you get. So whatever amp you get make sure it it 1 ohm stable and make sure you follow the recommended power/ground wire size. for 1200 + watts I would use 1/0 at leastfor ground/power. Are you making an enclosure or using a pre-fab?
2004 Grand Prix GT
(2) 12" RE XXXs (04/05 XBL^2)
5 cu. ft tuned @ 35 Hz
MMATS HD4000.05
MMATS SQ4100
Infinity Kappa components
Juice Box black cherry
Duralast platinum group 34
1/0 KNU OFC, 2/0 welding
Singer 250A
  • Who's Online   0 Members, 0 Anonymous, 2219 Guests (See full list)
