I am new to this forum but not new to car audio and modding. Here is a build log from this past week from me installing my system in my 08 Nissan Altima.
Just to note to not take credit for someone elses work I did not construct the fiberglass pieces. I purchased them.
Day 1 I received the 2 12" Rockford Fosgate P2 dvc subs and sub box. Along with 2 Arc audio amps (1000.1 and a 300.4) and 2 custom made amp bases.
By douglauver138 at 2012-05-29
Also I routed the 2nd 4gauge power wire to the trunk nice and neatly routed along one of the factory wire harnesses.
By douglauver138 at 2012-06-05
In this picture you can see what Nissan calls a subwoofer. It's the small black thing.
Day 2 I started preping all the wiring on the back of the amp bases for easy connection once in the trunk.
Takin a break...
Once the weekend came I got the rest all finished.
Getting more wires ran into the trunk.
Took the subs back out to mount the box to the car and connect more wires. She is starting to come together!
Subs are re-mounted.
Amps in place and getting wired up.
WIRES, WIRES, WIRES!!!
Front fascia piece in place and all wires tucked away!
By douglauver138 at 2012-06-04
That's how she sits as of now. I work in a machine shop and I am going to re-make the front fascia
to make it a better fit and I am going to make a diamond plate floor piece and cut the Rockford
symbol in the center.
Once it is all done I will post more pictures. I really like how it turned out and it sounds great.
What did you do for mids and highs upgrade? And how much boom do you get from the trunk? It all looks really nice and clean but sealing off a trunk like that with no way to port into the cabin(that I can see) is probably hurting you.
Looks really good and clean. This is Andrew btw and welcome to the forum.
Does that apply to sealed, as well as ported boxes Edited by Crandis16
Im curious to see what is the factory subwoofer screwed into, is it a box under the seat or something?
I just realized that I have the same thing in my car. In 1998 it was fully loaded and even had a "premium" sound system lol. I did notice wires running to it so I wouldn't be surprised if it's a subwoofer but I'm not really sure right now
So you're using the Arc 300.4 to amp those Bose or just not using it right now? And any plans on porting the rear lid or anything?
Correct it's powering the bose. I wasn't sure how it would sound with the stock speakers but it sounds really nice. Bose puts some nice systems in cars. I do not plan on porting the rear deck right now. I am still working on the trunk as far as making the fit and finish perfect. The sound is great the only part I may want to change out is the front door speakers. I feel as though it I changed those out to some speakers with good highs it would sound a lot better. The only part that seems lacking are the highs.
