CHEVY4X4BLAZER Posted June 6, 2012 Report Share Posted June 6, 2012 Have you tried a jump start? Your alternator does NOTHING with the engine off. Quote Link to comment Share on other sites More sharing options...
bassface Posted June 6, 2012 Report Share Posted June 6, 2012 It was a deka intimidator. Quote Link to comment Share on other sites More sharing options...
b-dubs89 Posted June 6, 2012 Report Share Posted June 6, 2012 if you got an accurate reading of 8 volts from your battery that is probably not enough for the computer to operate or any other systems .one way i test an alternator as far as working or not is get it running and carefully disconnect the battery if the engine dies after you disconnect the battery the alt is not charging and the engine and everything was running off the batt Quote Link to comment Share on other sites More sharing options...
Guest Posted June 6, 2012 Report Share Posted June 6, 2012 if you got an accurate reading of 8 volts from your battery that is probably not enough for the computer to operate or any other systems .one way i test an alternator as far as working or not is get it running and carefully disconnect the battery if the engine dies after you disconnect the battery the alt is not charging and the engine and everything was running off the batt this is true. a battery shouldn't just up and die like that in 3 months. your alt not charging could be the main cause. Quote Link to comment Share on other sites More sharing options...
Kyblack76 Posted June 6, 2012 Report Share Posted June 6, 2012 Yo, Trey,,, grab me a beer eh?.... Opps, posting out loud.. Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Mr.BassMan Posted June 6, 2012 Author Report Share Posted June 6, 2012 if you got an accurate reading of 8 volts from your battery that is probably not enough for the computer to operate or any other systems .one way i test an alternator as far as working or not is get it running and carefully disconnect the battery if the engine dies after you disconnect the battery the alt is not charging and the engine and everything was running off the batt the car wont even start so i can do that, and i thought if i put the meter to pos and neg of alt it would tell if alt is good or not. and i was wondering the same thing, idk what would cause the battery (if thats the case) to just all the sudden go shit on me. maybe a faulty battery? Quote Kenwood HU Kicker ZX2500.1 15" Kicker L7 (x2) Memphis 1/0 Wires 9^3 @ 31hz DC Power SP 250 Alt. 2 Deka "Intimidater" Batteries Big 3 Stock door speakers (For now) Link to comment Share on other sites More sharing options...
CHEVY4X4BLAZER Posted June 6, 2012 Report Share Posted June 6, 2012 Did you notice a loss in performance from the vehicle? Quote Link to comment Share on other sites More sharing options...
Guest Posted June 6, 2012 Report Share Posted June 6, 2012 if you got an accurate reading of 8 volts from your battery that is probably not enough for the computer to operate or any other systems .one way i test an alternator as far as working or not is get it running and carefully disconnect the battery if the engine dies after you disconnect the battery the alt is not charging and the engine and everything was running off the batt the car wont even start so i can do that, and i thought if i put the meter to pos and neg of alt it would tell if alt is good or not. and i was wondering the same thing, idk what would cause the battery (if thats the case) to just all the sudden go shit on me. maybe a faulty battery? the alt only works when the car is actually running. it could be a faulty battery, could be a bad alt. if you want, you could take the alt out of the car and take it to autozone or some place so they can test it. Quote Link to comment Share on other sites More sharing options...
Kyblack76 Posted June 6, 2012 Report Share Posted June 6, 2012 Lets sniff around... at OP...Why did you put a new battery in? cuz it went dead ? with that, When you intalled the new battery you just picked up, was there some bubbling, foaming, or a shit ton of corosion on the old battey posts and such?? Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
b-dubs89 Posted June 6, 2012 Report Share Posted June 6, 2012 if its easy to yank out your alt , go get it tested , throw a charger on your bat Quote Link to comment Share on other sites More sharing options...
