How much power to put out with this amp / sub combo?
I have 2 Rockford P3 12's and a Soundstream 1050 amp.
http://www.onlinecarstereo.com/CarAudio/p_18706_Soundstream_XTA10502.aspx
For the amp it says -
  • RMS Power @ 4 ohm: 2 x 260 Watts
  • RMS Power @ 2 ohm: 2 x 520 Watts
  • RMS Power @ 4 ohm Mono: 1 x 1050 Watts
And for the subs it says -
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
I wired the subs to 4ohm and put it mono on the amp. And im guessing my friend turned the gain up too much while he was trying to tune them and they started smoking out of the port. I turned them off as soon as i saw a little bit of smoke. Wired them to 2ohm and 2ch on the amp, and now they play fine (they just smell a little when played at full volume), but i can play them pretty loud and they still hit hard even when played for 10+ minutes straight.
If you have 2 subs that are 500rms each. Would you use a 1000rms amp to power them properly, or 500rms? Im confused on how this works. And the box leaks air pretty bad, but they havn't fried since switching to 520rms about a week ago.
wire the subs to 1 ohm and turn the gain down alot. if a sub calls for 500rms, you should give it 500rms. so you got the right idea. wire to 1 ohm to give them the full potential of the amp, but dont fuck the the gain. alot of gain = more smoke.
and patch the leaks on your box, dont slack on the most important part.
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
and welcome to the forum man, you'll learn alot (and it seems like you have alot to learn!)
2005 Subaru Impreza
My build log.
wait im retarded. keep wired at 4 bridged.
2005 Subaru Impreza
My build log.
i think you might want to re-read the amp specs. its 4 ohms stable bridged.
2 500w subs need a 1000w amp
damn glad you caught it yourself lol
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
yeah me too, i should post in the drunkasses thread from now on.
ill let you guys take it from here before i burn someones amp up
2005 Subaru Impreza
My build log.
Im actually making a new box today, i have another thread for that if any of you can help out with that too.
http://www.stevemead...__fromsearch__1
thanks man, i've actually been looking on this forum for a couple months now. never got around to making an account. I do have a lot to learn, but i just love nice cars and loud subs!
so should i bridge it mono to 4ohm so its at 1050rms and just watch my gains, or use 2ch at 2ohm for 520rms? This is a daily driver, and i play the subs all the time so i dont want them to blow real easy. I have it at 2ohm right now and it hits pretty damn hard even with a terrible leaking and broken box.
Edited by parker6594
2ch 2ohm 520w is near identical to 4ohm bridged 1050.
Either way you can push the gain too far.
Hammerdown... 1%
  • Who's Online   1 Member, 0 Anonymous, 1612 Guests (See full list)
