Alvy84VTS Posted June 7, 2012 Report Posted June 7, 2012 Hi community, Always here from Italy to ask your help for my project (Sorry for my not perfect english) I have 4 Soundstream Tarantula T6-15 subwoofer and 2 Soundstream X3.60 amplifier (about 5000 watt total for the subwoofers). I want to buy a wall in my car, a Citroen Saxo VTS but I have never built a bog box like that before so I really need your help. I am interested in doing hair trick but also have a "loud sound" from my subwoofer box, I hope this two things can be done by a single box! I think that having a box for hair trick don't allow me to have the loudest sound from my subwoofer but with 4 15" I think I can have loud After the explanation of my idea I write here parameters of my subwoofers copied from manual: Fs (Hz) 27,14 Qms 3,286 Vas (ft³) 3,732 Cms (mm/N) 0,117 Mms (g) 297,5 Xmax (mm) 20 Xmech (mm) 30 Piston diameter (in) 12,48 Sd (in²) 123,8 Qes 1,115 Re (Ω) 6,66 Z (Ω) 8 BL 17,15 Rms power (watts) 1000 Qts 0,832 NO (%) 0,185 1w/1m SPL (db) 84,68 Voice Coil diameter (in) 2,5" Impedance (Ω) DVC 4Ω M-vd (ft³) 0,242 Overall diameter (in) 15,5" Overall Height (in) 9,25" Mounting depth (in) 8" Cutout diameter (in) 13,875" Flange Width (in) 1" Flange Height (in) 75" <---- I don't know what is this but I think that 75 inches are a really big number for a subwoofer parameter! maybe an error. Weight (lbs) 27 Thank you for your help!!! Quote
Alvy84VTS Posted June 9, 2012 Author Report Posted June 9, 2012 Hi, I hope in your help for this box.. I ask you because I see really good works in this forum adn I am a newbie to calculate volume and port for box Quote
Joe X Posted June 9, 2012 Report Posted June 9, 2012 I don't you have 12 cubic feet + displacements in that car for a ported wall. Quote
Alvy84VTS Posted June 9, 2012 Author Report Posted June 9, 2012 Sorry but I don't understand... You tell I need a box of 12 cubic feet? Or I need box + 2cubic feet of volume in the car? Thank you Quote
Joe X Posted June 9, 2012 Report Posted June 9, 2012 The first thing you need to look at when considering a setup is this: http://www.soundstream.com/AudioProducts/Subwoofers/tarantula.htm T6-15: 3 cubes per sub, 4 subs 3x4= 12 cubes and that's without displacements. Quote
Alvy84VTS Posted June 9, 2012 Author Report Posted June 9, 2012 So 12 cubes of volume + the volume of the 4 subwoofer right? The volume of the port was included in the 12 cubes or I have to have 12cubes + subs volume + port volume? But I can confimr that I have this space in car because I will use all space, from the back of front seats to the end of the car, for the box... but I need help for this box, for the correct volume and port to obtain hair tricks if possibile! Quote
Joe X Posted June 9, 2012 Report Posted June 9, 2012 Plus the volume of all the wood, get the max dimensions for the box, removing everything behind the front seats. Quote
Alvy84VTS Posted June 9, 2012 Author Report Posted June 9, 2012 I will calculate it and I will post here dimensions available for the box... I hope in help after the dimension to calculate it and the right port Quote
Alvy84VTS Posted June 15, 2012 Author Report Posted June 15, 2012 (edited) Ok, I have checked in my car and I have 12 cubes of volume free to built the box for wall. I have more than 12 cubes so I can realize a box woth 12 cubes + subwoofers + port. Could you help me in calculating dimensions of box and port? I remember I am interested in doing hair trick and, if possibile, sound loud Thank you very much! Edited June 15, 2012 by Alvy84VTS Quote
Joe X Posted June 15, 2012 Report Posted June 15, 2012 It would be better if you posted the actual dimensions of the box. Quote
