Can someone help me out here? As most you may know by now, I drive an older ('84) F250 & well, my tires are going bald, but getting 16.5" tires is hard as f*ck, I literally went to 10 tire shops & only one had a 16.5 tire, old as hell for $50. <_<
So basically, I want to replace the almost extinct 16.5" wheels with newer ford 8 lug wheels, only problem is my bolt pattern is 8x6.5(165mm) & the wheels I can get for cheap are 8x117mm.
So can I safely put those wheels on my truck? or do they absolutely have to be 8x6.5?
Edited by AUDIOADDICT02
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
I know a couple guys that run 170mm adaptors mind you these are on mud trucks but none the less thats one route you could go
Current Ride
'95 Cutlass Ciera
Pioneer DEH-P8300UB HU
Alpine SPR-69C Rears
Boston S35 dash speakers
Crescendo Audio CCX65's glassed in the doors
Sundown audio SAX-100.4
Kicker ZX1500.1
Fusion PP-SW150 15" sub (switching to something better when I get some cash)
Rockford Fosgate RCF2D
optima yellow top D75
stinger 1/0 gauge wiring
Thanks for the response man. The problem with that is the adapters are $200 a pair, iirc, & they would make my truck look hella mexiflush since I'm planning to put normal truck wheels, not mud grapplers.
As of now, I'm stuck between late model Chevy 8 lug factory wheels or H2 wheels since they are 8x6.5 bolt pattern.
I did not know that, I'm going to look into that since adapters are out of the question.
  • Who's Online   1 Member, 0 Anonymous, 1618 Guests (See full list)
