This is the box build.
If i need to rebuild it to get my lows them thats what i will do.
My box is 14 cubes
the port is 132sq in and 13in long
http://www.stevemeadedesigns.com/board/topic/135404-buick-century-wall-i-just-got-in-from-putting-in-work-5min-ago/
Walled 2002 buick century A.K.A "Betty sue"
polk 5 1/2 front doors
4 3in pillar speakers
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
:build: http://www.stevemeadedesigns.com/board/topic/162721-buick-built-in-trunk-fi-sp4-hifonics-2400/
more port. you have less than 10 inches per cube
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
my set up does hurt a bit at 40-50hz but id rater have my lows hurt lol
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
okay say i re do the wall and built the port 250" would it help my lows?
How much port area should i go with?
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
If you're at 14cuft net with 132" of port, you should be in the 32-33Hz range. So tuning isn't bad. But your port area is minimal for even an aero.. I'd shoot for 220ish. :)
Edited by loudNlow87
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
Okay cool!! i knew i was tuned somewhere in the 30's but the strange thing was when i did go get metered my car put up the best score @46hz i thought it was a bit strange because im tuned low.
if i keep my center vertical port i would be able to do 260sq in max
If i rebuild the wall and do a drivers side port. the world then becomes mine. hell i could have up to 500sq in of port.
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
  • Who's Online   2 Members, 0 Anonymous, 1828 Guests (See full list)
