true, i think it would be more simple to just widen out my existing port. Would it work if i made the 6" aeroport with bends not with an L shape, but a T shape?
how would i calculate the length of the port that way?
T would get complicated.
If its a tru basic T then you would get cancelation .
the T part would need to be 1/2 the area of the rest of the 6" port.
Stick with either an L or a few 45deg elbows well place . It will be simpler.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
cancellation does make sense. it would just be a bit difficult because my port is dead center so idk if i should L line it to the left or right and not completely sure a 6" tube would fit behind the subs in the box.
