I've never understood why ppl use 3 subs, only odd number of subs setups I see, when it will give you a weird ohm load. Only amp I could see working with that is a Slash series from JL since they are 1.5-4ohms stable with the same amount of power at any load.
/Rant
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
that vid is from a member here,purplehaze. and op the name of the song was in the comments on youtube
xbox 360 gamertag-greenrocks420
Not insulting you or anything, but did you just call us "bloody winging fairies" ?
/Rant
Space is an issue some times. Better running 3 right size subs in the enclosure, then cramming 4 that require more airspace, and sounding like shit due to lack of space.
Also running 3 subs, You can wire lower then, say maybe .7 instead of .5, and not increase the risk of blowing your amp as much.
That is my theoretical answer.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
  • Who's Online   0 Members, 0 Anonymous, 1035 Guests (See full list)
