i fixed it, and changed things a hair. . . box dim are very close in drawing and basically represent 98% of the box. hows that look? is it bad to angle the port up the rear wall?
3D modeling software FTMFW. I have only used Pro/Engineer and I use Inventor at work. overall looks good and everything seems to be in check
although shouldn't you aim for 17 in^2 / ft^3??? and shouldn't you try to get the port area in between the values that it gave you? I'm still a noob at box designing
Edit: Ninja'd^^^^^^
Edited by Crandis16
Edit: Ninja'd^^^^^^
lol thats what the range thing is for? haha
Edit: Ninja'd^^^^^^
like I said I'm still a noob but I'm pretty sure thats what you want to do. If you get it in that range then I believe you will achieve the correct port area to net volume ratio.... once again I'm not expert, I would try asking someone who has built more than one box in their life hahaha. I've designed probably 5 or so now but most have been scrapped due to change of plans
