CURRENT
Exterior:
30% metalized tint all around
17x7 Tenzo R rs5 rims
stainless steel lugnuts
red painted calipers
VHT Nightshade tail lights.
JLM 6000k 35watt HIDS
sticker bombed rear windshield
Interior/audio:
Sony CDX-GT650ui headunit
Kicker KS 6x9 and 3.5" speakers
Pioneer GM-3400 2 channel amp
Crescendo Bc2000d
2 12" AQ HDC3
Diehard Platinum g34 under the hood
Kinetik HC1800 in the trunk.
Audiotechnix OFC 0awg.
Suspension:
Megan Racing lowering springs - 1.7" drop in the front. (stock rear springs due to sag from audio)
I realize i may get some initial hate from the first few pics, but i think things start to get better.
inside look!
made a complete rookie mistake, made the cut out exactly 12" and the sub slipped right through. so i used the mounts from the prefab box.
JLM 35w 6000k HIDS (yes they look green in the pic but are pure white with a hint of blue)
upgrading the highs on a budget Kicker DC35
Yup changed on the embarrassing blacked out hubs to 17" Tenzo R RS5 rims
looks good, except, that port looks way to small man, that will really effect your output levels
I've built quite a few enclosures for those, Through experimenting I found you can put one of those in an enclosure that is about 3 cubic feet and have more output and deeper lows than 2 in the same cubic feet. had all 4 doors on my friends camery flexing.
aside from making the cutouts too big and port area, looks like a nice simple setup!
quick question though, why the 1223's and not this years model?
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Ok the box was quite a bit bigger now that im looking at it. I think is was 3.25 tuned @36 or so heres a pic of it after we put a type X in it, but the type R was louder and performed better in this box because i designed it to the specsof the R
Ok the box was quite a bit bigger now that im looking at it. I think is was 3.25 tuned @36 or so heres a pic of it after we put a type X in it, but the type R was louder and performed better in this box.
so a type r 12 was louder than a type x 12 in the same box and same power ?
2 12ks and i dont know what to do
build in the works!
Ok the box was quite a bit bigger now that im looking at it. I think is was 3.25 tuned @36 or so heres a pic of it after we put a type X in it, but the type R was louder and performed better in this box. That box was in no way made for the type X at all.
In this application, yes, but the box was carefully designed for the type R to reach full output, while maintaining good SQ if I had designed it for the X, I could have made it smash harder, but would need more power, and a smaller box for the type X, This box was way to big for it. you could tell it lost power handling. It all comes down to the box.
we were using that 1,000w RMS alpine class D.
Iv had lots play time with a type x wich is why i chose it over a w7 at the time cuz it was louder and equaly sound quality worthy in all applications i ran it thru so i dont see how a straight drop and play from a type r to an type x that the type r was better in this scenario no matter what box design
Edit: op build looks good
build in the works!
The box was way to big, the response was all jacked, the box being so big really narrowed down the frequency response and cause the speakers response to dip off really bad in both directions. causing it to have a very narrowed area of musical playability, and drastic sound differences from hz to hz in the tuning area, think about it like this, if you put a 15 in a box that is 6 cubic feet and tune it to 50hz, it going to play that 50hz tone really good, but nothing else, (just for example, no pen and paper math involved)
The response of the type R 12 was more rounded in this design, where the response of the type X in this enclosure was more like "/\" peaking hard at the tuned hz and falling off rapidly on lower or higher hz,
the type x also requires more power to get moving (its made with heavier parts, has a plastic cage reinforcing the cone) therefore to exceed the output level it need to see more power.
Now another thing to keep in mind, this was from the current models 6 or so years ago, i am sure they have changed a lot since then.
