Well, I had decided to keep my setup I have now instead of selling it.. So I went to put everything back inside the car, Amp/sub/box. Well I do so and I'm having problems. My amplifier turns on no problem, but it's not sending a signal to the subwoofer. So I check the gains everything is fine, i put the wires onto another speaker and I can slightly hear noise it makes not music, but static for the slight second i tap them onto the speaker. I checked the voltage it's fine at 13.4, the amp turns on so I would assume it's not for the remote.. RCA's are hooked up correctly. I'm kinda at a loss at this point, I would assume maybe bad RCA's being that I can hear the static from them, but there isn't music playing? Any ideas would be greatly appreciated. I do have a DMM but it's a cheapo from RadioShack. If it makes any difference it's a SKAR 1500.1 and a DC level 4 m2 12''. Thanks again.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
your sub volume section in you headunit turned up to normal operation setting ??
Yes sir. I only took out the box/sub. I left the amp in there with wires connected still but was sure to cut the neg, and pos speaker wires so they wouldn't blow the outputs.. so I'm almost positive that's not it. I'm thinking more along the lines of RCA's.. or Fuses being that when i was moving everything around my power touched the damn screw driver i had back there. But if the amp is getting power I don't think it would be any fuse under the hood/ or inside the car. So I'm thinking RCA'S. Not exactly sure how I can test that though.. When I was putting everything back together I relocated my amplifier to the back of the seat, doing so I wounded up my RCA'S and zip tied the extra to tuck away.. I think that's what did it.
being in SQ Competitions ... you never know, so I always try and keep a "test set" of RCAs in my tool box just to be able to throw over and test things like that ...
I've also been known to run RCAs from one cars headunit to another cars amps to test for signal ... lol
Edited by Cablguy184
