brandonlearL7 Posted June 21, 2012 Report Posted June 21, 2012 I bought a DC Audio Level 4 18" with Level 5 softparts about a month ago. Today I was playing Welcome Back by Young Jeezy, and when it hit the lows, it just sounded like air. This is the first time I've played anything low on the sub, and I just want to make sure I'm not going to damage it. I have it wired @ 1 ohm, gain on around 32 volts, subsonic around 30-35, bass boost off, LPF around 120hZ. If a video would help, I could do that and post it here. I'm just worried about damaging the sub. Vehicle: 1999 Toyota 4Runner SR5Front Stage: Oxygen Audio O2 ComponentsRear Stage: Oxygen Audio O2 ComponentsSubs: 2 12" Obsidian V2 w/ Upgraded Black Aluminum SPL coilsBox: 5.94 Cubic Foot Tuned to 34 HZSub Amp: American Bass VFL150.1 Mids/Highs Amp: Rockford Fosgate 120.2 Head Unit: Kenwood KDC-X396Electrical: Single Run of American Bass 1/0, Single Run of American Bass 8 Gauge, Big 3 Upgrade Build Loghttp://www.stevemeadedesigns.com/board/topic/161818-1999-toyota-4runner-sr5/
SnowDrifter Posted June 21, 2012 Report Posted June 21, 2012 Box specs? Is it the same one in your sig? Is your port rounded over? turn your low pass to 60hz too. Sounds a lot better. Turns down your subsonic too, 35hz might be your problem. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
brandonlearL7 Posted June 21, 2012 Author Report Posted June 21, 2012 Box specs? Is it the same one in your sig? Is your port rounded over? turn your low pass to 60hz too. Sounds a lot better. Turns down your subsonic too, 35hz might be your problem. i believe its 34Wx24Hx16D, 8 inch aeroport.. I'd have to check for sure. Vehicle: 1999 Toyota 4Runner SR5Front Stage: Oxygen Audio O2 ComponentsRear Stage: Oxygen Audio O2 ComponentsSubs: 2 12" Obsidian V2 w/ Upgraded Black Aluminum SPL coilsBox: 5.94 Cubic Foot Tuned to 34 HZSub Amp: American Bass VFL150.1 Mids/Highs Amp: Rockford Fosgate 120.2 Head Unit: Kenwood KDC-X396Electrical: Single Run of American Bass 1/0, Single Run of American Bass 8 Gauge, Big 3 Upgrade Build Loghttp://www.stevemeadedesigns.com/board/topic/161818-1999-toyota-4runner-sr5/
Guest Posted June 21, 2012 Report Posted June 21, 2012 theres lows in welcome back? its like all 40+hz
SojiaRaggs9000 Posted June 21, 2012 Report Posted June 21, 2012 maybe a decaf version? * Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )* Rockford Fosgate Balanced Line Driver * One FULLY LOADED ~ 10" DC m2 XL* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling* MechMan 240a High Output Alternator * KnuKonceptz Krystal Kable RCA Cables* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable* Five Exide Orbital ORB34M Marine 12 Volt Batteries* PowerMaster XS D3100 12 Volt Battery My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
brandonlearL7 Posted June 21, 2012 Author Report Posted June 21, 2012 theres lows in welcome back? its like all 40+hz Would it be possible that I have my subsonic too high then? Vehicle: 1999 Toyota 4Runner SR5Front Stage: Oxygen Audio O2 ComponentsRear Stage: Oxygen Audio O2 ComponentsSubs: 2 12" Obsidian V2 w/ Upgraded Black Aluminum SPL coilsBox: 5.94 Cubic Foot Tuned to 34 HZSub Amp: American Bass VFL150.1 Mids/Highs Amp: Rockford Fosgate 120.2 Head Unit: Kenwood KDC-X396Electrical: Single Run of American Bass 1/0, Single Run of American Bass 8 Gauge, Big 3 Upgrade Build Loghttp://www.stevemeadedesigns.com/board/topic/161818-1999-toyota-4runner-sr5/
Guest Posted June 21, 2012 Report Posted June 21, 2012 theres lows in welcome back? its like all 40+hz Would it be possible that I have my subsonic too high then? i dont know, maybe. where is it set?
