Ok so I finally got my measurements for my trunk n I know I want the box be 16 h 30 w and 30 l but my big problem is the port I still don't get how tune a part but all the help would be appreciated
Posted (edited)
A 18" in a trunk is a bad idea, I checked your previous thread so I know some of the missing data, I did a quick run for your numbers, sub up ports front/back and this came up:
Enclosure Specifications:
Fb = 34.5 Hz
Vb = 5.7 ft^3
External Height = 16.25 in
External Width = 30 in
External Depth = 30 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 30 x 30
Left & Right Sides = 28 1/2 x 14
Front & Back = 30 x 14
Port Quantity and Dimensions:
Number of Ports = 2
Pipe Port Diameter = 6
Pipe Port Length = 18
Do some serious top to bottom crossbracing.
You are going to need to deaden to hell the trunk lid.
Edited by Joe X
I tried for a slot and took up a lot of your already low net volume. I'd say aeros are the way to go in your case, sub up everything rattles a lot and you loose output, sub front or back are the better way to go in trunk cars.
But Im going try this and see what happens and do u think I'll be able do hair tricks and get alright numbers
