b-dubs89 Posted June 23, 2012 Report Posted June 23, 2012 i like the idea of finding when equipment clips like amps and head units , like the idea enough to where i am looking into buying an o-scope . i am seeing there are many options / variations . i don't need anything too fancy , all i want to do is check pre-amp signals from headunits and set amp gains for now and maybe in the future check out some of my home audio gear see where it clips . i have seen some 20 mhz scopes 30,60mhz , 500 mhz scopes , not sure but my educated guess is the 20 mhz scope should be suitable for what want . i have seen a few usb based o-scopes made to run on pc , don't know how well those work , seen some used scopes in the same price range . so if any one can tell what i should look for or if it matters what type of o-scope i get that would be helpful . my other thought is , can i use test tones from a cd for my o-scope tests ?
safiend Posted June 23, 2012 Report Posted June 23, 2012 I would just get the smd dd-1 personally man. New build coming soon..
b-dubs89 Posted June 23, 2012 Author Report Posted June 23, 2012 I would just get the smd dd-1 personally man. thought about that but for the same money or less i could have a scope , which could be a useful tool for other things
memphisBred Posted June 23, 2012 Report Posted June 23, 2012 I had good luck and enjoyed my Velleman HPS-10. Think that was the model number. Look into Velleman and TPI SMD Super Seller/Buyer Audison----Hertz----Rainbow
Ray Posted June 23, 2012 Report Posted June 23, 2012 Tpi-440 is very common 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
b-dubs89 Posted June 23, 2012 Author Report Posted June 23, 2012 Tpi-440 is very common that looks nice , but what about something like this http://www.ebay.com/itm/110900177799?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649#ht_1596wt_1270
Guest Posted June 23, 2012 Report Posted June 23, 2012 this is my scope. its worked perfectly fine for me on tons of headunits and amps. dont mind the clipped as fuck signal LOL i was retuning a buddys system.
Ray Posted June 23, 2012 Report Posted June 23, 2012 As long as you dont need your scope mobile. Sure. Also most bech scopes are not auto ranging. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Guest Posted June 23, 2012 Report Posted June 23, 2012 As long as you dont need your scope mobile. Sure. Also most bech scopes are not auto ranging. lol x2 this. mine is like 20-25lb and around 15-16" deep. definitely not mobile at all
