Cazz Posted June 27, 2012 Report Posted June 27, 2012 Well I have been asking around the forums for someone to help me out with designing but I didn't quite get the help I was looking for, but don't get me wrong I now know a lot more about car audio then I did before coming on this forum. But still Im as dumb as anything, I don't no how to wire and a lot more other things but hey ill get there. I think this is my first proper box although the subs had to be arranged out of line.
john253a Posted June 27, 2012 Report Posted June 27, 2012 The displacement of thoes subs are 0.1 each so u need to change that on Torres to 0.4 You need to add a baffle to the top and a shit load of bracing Idd you 1" or 1.25" round wood bar 2 up, 2 back and 2 side Aim for 2.4-2.8 net 40sq" of port So you port will be 15.75x 2.75or 2.625
john253a Posted June 27, 2012 Report Posted June 27, 2012 Even try a 1 common wall port 10x 4 or 10x 4.25
Cazz Posted June 27, 2012 Author Report Posted June 27, 2012 Ok so I appreciate the help but I have no clue what that is, I followed the tutorial on this forum, that's why all my other posts was asking other people to design a box and ill put it together.
Cazz Posted June 27, 2012 Author Report Posted June 27, 2012 Woop just realised again I messed up yet another box I understand the Woofer Displacement you mentioned, although I think you wrote the 10" SA Series which is 0.1 each. The 8" is 0.08 which means I should have put 0.32 and that would change the tuning to 35Hz and I want 33Hz so id have to change the port length which means just start over.
joh17 Posted June 27, 2012 Report Posted June 27, 2012 Random: WORLD OF WARCRAFT. . .LEAGUE OF LEGENDS. . .STEAM. NICE!!!
john253a Posted June 28, 2012 Report Posted June 28, 2012 I'm at work at moment so can't draw or use Torres to show you But the sa8v1 and v1.5 are 0.8 each the v2 is 0.1 each so you need 0.4 in displacement, When I say at a baffle that the middle 2nd from bottom box, put a 1 and leave the 1 under at 0.75 that will mean you need to change port to 15.75 as top will be 1.5" thick, then add 0.03 in in bottom left to allow for bracing 1 common wall port is straight accross the bottom If you put a 1 in bottom tight box And change port to 4.25high and 10 wide. Then play around with it some more, When I get home I'll help you out a bit more
Cazz Posted June 28, 2012 Author Report Posted June 28, 2012 Ok I now know what a baffle is and that means a second piece of wood on the top right? If it is that why would the port be 15.75 wouldn't it be 11.75? And thanks for helping.
