bassface Posted July 7, 2012 Report Share Posted July 7, 2012 you should cut your subwoofers down by 4, should fix the problem. Link to comment Share on other sites More sharing options...
Freshman6969 Posted July 7, 2012 Report Share Posted July 7, 2012 The only thing you haven't ruled out is the amp... this is was i was about to say, mind you i dident read through everything but the last page tells me you havent ruled out the amp, ill pretty much put money on the amp or your wiring( i know you said you checked it, but ive made my self nuts over a simple strand touching another) Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
Akslowroller Posted July 7, 2012 Report Share Posted July 7, 2012 The only thing you haven't ruled out is the amp... Like I said before you really need to try and get a dmm on your amp when it is cutting out. this is was i was about to say, mind you i dident read through everything but the last page tells me you havent ruled out the amp, ill pretty much put money on the amp or your wiring( i know you said you checked it, but ive made my self nuts over a simple strand touching another) Link to comment Share on other sites More sharing options...
Slapuhho Posted July 7, 2012 Report Share Posted July 7, 2012 Signal issue, prob the amp. 4 18's, low power and lots of gay fur. Team gg Team DOA My Videos Link to comment Share on other sites More sharing options...
