oeking87 Posted June 27, 2012 Report Posted June 27, 2012 Please Read Whole Thing Before Saying Something Stupid, Problem - Subwoofer cutting out at high volume! Subwoofers - Four 12" Swr-1243d 600rms Amplifier - Mrp-M2000 2000rms Gain & Bass Boost set as lowest point Alternator - 270xp Dc Power Batteries - One Yellow Top Optima Main Battery - & One Kinetics Hc600 Trunk Battery Voltage Drop - Lowest Point Hits 13.0v aplifier recomend 14.4v Ground - A gold battery post ran threw the car "paint removed" with a 1/0awg wire outside running to frame so to points of contact. Wires - All 1/0 Monster Cable with 200a fuses in place. Big three done. Headunit set - Bass +1 Mid 0 Treb +3 Sub +15 Maxed - Norm Vol 22 So what the f&%^ is going on why the f**^ is my s*%^ still cutting off its pissing me off so much i want to burn my care to the ground no matter what i set my amps gain it keeps happing at random times it driving me insane and yes all my wires are tight Sombody help please!
SnowDrifter Posted June 27, 2012 Report Posted June 27, 2012 Random times? Not just full tilt? Try this: run a wire from the + on your amp to the remote turn on on your amp so it's always on. If it works fine, your remote wire is wonky or you might need a turn on relay ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
n8ball2013 Posted June 27, 2012 Report Posted June 27, 2012 What load are you presenting to the amp. If you don't know we've found the issue THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Kyblack76 Posted June 27, 2012 Report Posted June 27, 2012 agree... voltage - which seems ok or Impedance.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
oeking87 Posted June 27, 2012 Author Report Posted June 27, 2012 It at 2ohm it the lowest my amp can haddle
alaskanzx5 Posted June 27, 2012 Report Posted June 27, 2012 ^ good question t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
n8ball2013 Posted June 27, 2012 Report Posted June 27, 2012 Could also be a bad woofer or a woofer seeing a short. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Sanitarium Posted June 27, 2012 Report Posted June 27, 2012 What load are you presenting to the amp. If you don't know we've found the issue
oeking87 Posted June 27, 2012 Author Report Posted June 27, 2012 tell me about it never had this problem i think i have a ghost in my car that hates lound music
oeking87 Posted June 27, 2012 Author Report Posted June 27, 2012 Could also be a bad woofer or a woofer seeing a short. Can i test for that?
