AA98hoe Posted June 30, 2012 Report Posted June 30, 2012 Sounds like bad rcas or a bad sub...if amp stays on then has to be those problems TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
oeking87 Posted June 30, 2012 Author Report Posted June 30, 2012 have you checked your fuse under the hood? youd be surprised, i was at work and a similar issue came in, i wasnt seeing a full 12v at the amp like i normally would, i looked at the fuse and it was not blown/black, took my dmm and saw a huge voltage drop on the amp side of the wire, swapped the fuse for the hell of it and sure enough the problem was gone customer had the same problems as what you are describing with subs cutting out at random times That didn't work
oeking87 Posted June 30, 2012 Author Report Posted June 30, 2012 Sounds like bad rcas or a bad sub...if amp stays on then has to be those problems I but new rca's that didn't help so i guess subwoofers i got four so how the hell am i going to find which one is causing the problem when this happens at differnt times?
oeking87 Posted June 30, 2012 Author Report Posted June 30, 2012 And it seams like it happen more often when im driving maybe a wire came loose on a spider or something my car ride pretty smooth so i don't think its from road bumps or nothin like that idk
oeking87 Posted June 30, 2012 Author Report Posted June 30, 2012 Your setup sounds il dc98hoe my next subs are going to be two 15" AA mayham's and i tring to sell my two Mrp-m2000's and one directed 1100d (old school) on ebay to get a crescendo 5500 but no one seems to want to buy them.
SCOTT KOCH Posted June 30, 2012 Report Posted June 30, 2012 Why do you have your sub volume maxed?Have you tryed turning that down to see if it helps. This is very hard for me to say this but......there is such a thing as too much bass.......eeeekss sorry its hard to say that!!!!!!
oeking87 Posted June 30, 2012 Author Report Posted June 30, 2012 its at 15 out of 15 and i have never had a problem with it set to this with other systems but to answer your guestion yes i tried turning it down.
oeking87 Posted June 30, 2012 Author Report Posted June 30, 2012 Its got to be the ghost of some old man who hates loud music! oooooooooooooooooooowwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
oeking87 Posted June 30, 2012 Author Report Posted June 30, 2012 another f&%ed up thing is alot of the times song that don't bump all that much like (Snap Backs & Tattoo's) Make it happen alot but something loud as s*%# like (Mercy) or damn near any 40 water s*%! does it less often.
Skullz Posted June 30, 2012 Report Posted June 30, 2012 One thing you should check would be the connections to the subs cause if your getting intermittent sound then something is loose and losing connection either at the amp or the subs. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
