Redcorn245 Posted June 28, 2012 Report Share Posted June 28, 2012 does any one have recommendations for a boxfor them. i have a jeep and 1500 watts for them. looking for a ported box with nice spl Quote Link to comment Share on other sites More sharing options...
CleanSierra Posted June 28, 2012 Report Share Posted June 28, 2012 does any one have recommendations for a boxfor them. i have a jeep and 1500 watts for them. looking for a ported box with nice spl What Jeep do you have? That answer will make all of the difference. Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Redcorn245 Posted June 28, 2012 Author Report Share Posted June 28, 2012 does any one have recommendations for a boxfor them. i have a jeep and 1500 watts for them. looking for a ported box with nice spl What Jeep do you have? That answer will make all of the difference. i have a 99 jeep grand cherokee laredo Quote Link to comment Share on other sites More sharing options...
CleanSierra Posted June 28, 2012 Report Share Posted June 28, 2012 Have you taken a tape measure to the cargo area to see what you want to work with, dimensions wise? We need a width depth and height that you can be comfortable with. Best configuration for that vehicle would most likely be both suns firing up and port to the back. Port along the bottom of the box. Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Redcorn245 Posted June 28, 2012 Author Report Share Posted June 28, 2012 i pretty sure i dont have any size restrictions. i just want to get the most out of them that i can. im replacing my hd12 with them so id like as much as i can get lol if that makes any sence. Quote Link to comment Share on other sites More sharing options...
CleanSierra Posted June 28, 2012 Report Share Posted June 28, 2012 Well you should post at least your workable width across the back and depth, height can be adjusted accordingly. Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
Redcorn245 Posted June 28, 2012 Author Report Share Posted June 28, 2012 (edited) well the width is a little over 43 inches at its narrowest point and a little over 36 long. i think thats what your asking for right?> Edited June 28, 2012 by Redcorn245 Quote Link to comment Share on other sites More sharing options...
Redcorn245 Posted June 28, 2012 Author Report Share Posted June 28, 2012 Have you taken a tape measure to the cargo area to see what you want to work with, dimensions wise? We need a width depth and height that you can be comfortable with. Best configuration for that vehicle would most likely be both suns firing up and port to the back. Port along the bottom of the box. bass box pro reccommends a sealed box for them. i want a ported tho. you think i should go subs up port back? Quote Link to comment Share on other sites More sharing options...
Joe X Posted June 28, 2012 Report Share Posted June 28, 2012 Here is a suggestion 1.5 cubes per chamber: Enclosure Specifications: Fb = 35 Hz Vb = 3 ft^3 External Height = 17 in External Width = 33 in External Depth = 18 in Port Width = 3 1/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 33 x 18 Left & Right Sides = 16 1/2 x 14 3/4 2x Front = 14 7/8 x 14 3/4 Back = 33 x 14 3/4 Shared Port Internal Assembly Parts: 2 x Front to Back = 14 7/8 x 14 3/4 2 x Extension = 8 15/16 x 14 3/4 Generic dimensions assembly guide: PM questions if any as I don't check so frequently this section. Quote Link to comment Share on other sites More sharing options...
Redcorn245 Posted June 28, 2012 Author Report Share Posted June 28, 2012 (edited) Here is a suggestion 1.5 cubes per chamber: Enclosure Specifications: Fb = 35 Hz Vb = 3 ft^3 External Height = 17 in External Width = 33 in External Depth = 18 in Port Width = 3 1/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 33 x 18 Left & Right Sides = 16 1/2 x 14 3/4 2x Front = 14 7/8 x 14 3/4 Back = 33 x 14 3/4 Shared Port Internal Assembly Parts: 2 x Front to Back = 14 7/8 x 14 3/4 2 x Extension = 8 15/16 x 14 3/4 Generic dimensions assembly guide: PM questions if any as I don't check so frequently this section. hey wow thanks alot man i appreciate it. im going to make this box either today or tomarro. is this box good for spl, sq, or both? what are the benefits of running the subs up, port back? im fairly knew to the whole box design thing lol only thing i can really do is cut the wood and put them together lol. what program do you use? thanks again man. ill post some videos of the build and final results if any one cares...........one more question... are thoes pieces in the corners included in this box or will adding thoes add more displacement? Edited June 28, 2012 by Redcorn245 Quote Link to comment Share on other sites More sharing options...
