Hey guys i have 2 dc audio level 4 m2 15s and a mtx te4001d amp. Want a ported box for musical so tuned around 32-34 hz and that would still be ok to get some ok spl scores and its going on a mini ext. Cab truck. Any help i really appreciate it thanks
These are the outside measurements which is. Wide 50.5in.in. depth 16in. height i can go up to 32in. And its a nissan pickup ext. Cab. Let me know if its better subs up and port up or subs up port towards the driver side. Recommended space they ask for is 3.25 cu.ft. but im also overpowering the sub. Thanks
So I'm gonna give each 15 3cu.ft. after displacement. The subs and port are gonna be facing up. Port on driver aside and subs on passenger side. My depth of the box is 16 in so the subs fit perfect. The port facing up is gonn be next to the sub so the height is gonna be 14.5 inch subtracting the 1.5 in from the .75 in of the wood. My question is should i make my port wider our smaller cause i don't want too much port noise and how long should it be to tune it to 33 hz. The box total volume is about 7 cubes so if any one can help i would really appreciate it. Thanks.
A box 20H x 40.5W x 20D box would give you 6 cubes net, each driver displacement is 0.21 cubic feet. And that is with rather low port area.
The measurements with the subs facing up that goes with depth of the box are 50.5W x 19H x 16D and those are the external dimensions which give me 7.19 cubes before displacement so how much sq.in. should be fine for that size box and tuned to 33hz?
This would need to be done to reach 6 cubes and enough port area to avoid port noise:
Enclosure Specifications:
Fb = 33.5 Hz
Vb = 6.0 ft^3
External Height = 20 in
External Width = 50.5 in
External Depth = 16 in
Port Width = 5 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Top & Bottom = 50 1/2 x 16
Left & Right Sides = 14 1/2 x 18 1/2
Front & Back = 50 1/2 x 18 1/2
L Port Internal Assembly Parts:
Top to Bottom = 12 3/4 x 14 1/2
Extension = 2 x 14 1/2
Assembly guide (GENERIC DIMENSIONS):
Make sure to make a top to bottom crossbrace between the subs.
Edited by Joe X
And a double baffle would also be recommendable if you are willing to go 0.75 taller.
Edited by Joe X
Id there any way to keep the depth of the box at 16 in.? That's my max space i got to work with on the depth and what's the height of the port and the length with the width being 5.25 in.?
Yes, I modified the height, the (updated) 5 3/4 is the port width, the port height or in this case the port depth is given by the box depth less the 1.5 from the front and back walls, if you just cut the parts listed it all assembles as shown in the sketchup. Any other questions let me know.
  • Who's Online   0 Members, 0 Anonymous, 599 Guests (See full list)
