stuck and needed some info alts,and big 3
alright,
1. I know its no sorta answer, but safe two run to batts on the stalk alt?
2. if i cant get a aftermarket alt, what should i do?
3. i did the big three with 4ga, but i mite need to redo the alt to the batt cause when i was under my car it was set up like this
[alt]-----[starter]------[battery]
the alt wire just ran to the starter(so i kept it the same way and just ran the 4ga to the alt to starter) the the starter wire ran to the battery, but do you think i should just run the alt wire straight to the battery?
1. yes
2. put it in
3. word
alt straight to bat
Current Setup: , 2 Fi sp4 18s in a big ass flat wall tuned to 23hz, Pioneer 80prs, 2 Digital Designs m3bs strapped @ 2 ohms, Banda ICE2000, Crescendo 800.4, 4 PRV 10MR1000s,4 Mclaren MLT300 Super Tweeters Kinetik 2000 XS Power 2700 & XS Power 3100s.
What system are you running, what car?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
i plan on when getting enough is building on my Saturn sl2 it would be different to see , and as of right now i got jvc kd-r730 , and a kicker 750.1 but i wanna build up
  • Who's Online   0 Members, 0 Anonymous, 2107 Guests (See full list)
