AB18VFL Posted July 3, 2012 Report Posted July 3, 2012 Can it be heard 2 blocks away, thats how i rate systems. LMAOOOOOOOOOOO SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!! 2005 Subaru Impreza My build log. Head unit- Kenwood Excelon KDC-X695 Front doors- Rockford Fosgate 6.5" Prime components Rear doors- Rockford Fosgate 4" Punch coaxials Sub amp- Audiopipe AP18001d Subs- Two American Bass TNT 10"s Box- 2.6 cubes @ 34hz, 36in of port Big 3 & run of Raptor 1/0 to rear powercell TEAM 808 UPSTATE NY. Can it be heard 2 blocks away, thats how i rate systems.
Gnarkill Posted July 3, 2012 Author Report Posted July 3, 2012 im not that impressed by the system but i works until i find better woofers bigger amp and change the front speakers. im thinking about putting in 3 10" woffers for more power, im currently running 2 10" Mtx T6610-44 at 1ohm. when im standing outside the car you cant even hear the stereo sound so thats good. does anyone have any recomendations on some good 10" subs and a good amp? how do i setup the gain volym knob that came with the amp? i have a litte problem also with the sub, i sanded it down yesterday so it would fit in the trunk more precise, but now when i open the door or window on the car the overall volume of the bas goes up alot, what can be the cause of this?
purplesyrup Posted July 4, 2012 Report Posted July 4, 2012 im not that impressed by the system but i works until i find better woofers bigger amp and change the front speakers. im thinking about putting in 3 10" woffers for more power, im currently running 2 10" Mtx T6610-44 at 1ohm. when im standing outside the car you cant even hear the stereo sound so thats good. does anyone have any recomendations on some good 10" subs and a good amp? how do i setup the gain volym knob that came with the amp? i have a litte problem also with the sub, i sanded it down yesterday so it would fit in the trunk more precise, but now when i open the door or window on the car the overall volume of the bas goes up alot, what can be the cause of this? You sanded down your sub?
REVOofRustler Posted July 4, 2012 Report Posted July 4, 2012 The sub will always be louder when you open any windows or doors. It just makes it easier for the sub to move because it has much more air to work with. 2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant - Fi and Crescendo - Stock Bose System - http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota 136.4 Sealed @ 29hz 137.0 Drivers window open @ 26hz
purplesyrup Posted July 4, 2012 Report Posted July 4, 2012 there is many answers to your question if you browse around, tuning your amp is a trial and error deal based off of your box, tuning, subs ect, sounds like you need a friend that is near by that understands car audio, if you cant hear your system from outside your car, there is something wrong. 2 10inch subs will easily be clearly audible from outside of your car take some pictures of your stereo setup so we can further understand what is going on here
Gnarkill Posted July 4, 2012 Author Report Posted July 4, 2012 I sanded down the sub box not the subs=) nope no friends that are doing car stereo or is interested in that kind of work so i have to do it my self, otherwise i wont learn anything =P. i have been sound proofing the car on the inside of the trunk and in the Coupé so thats why you cant hear so much on the outside i think, i can try to adjust the sub box to find the best place in the trunk were i get the most preasure in to the coupé, I have the bass elements and the slotted vent to the back rest in the back seat, Im going to take som pictures of my ongoing work and post them here for you.
purplesyrup Posted July 4, 2012 Report Posted July 4, 2012 I sanded down the sub box not the subs=) nope no friends that are doing car stereo or is interested in that kind of work so i have to do it my self, otherwise i wont learn anything =P. i have been sound proofing the car on the inside of the trunk and in the Coupé so thats why you cant hear so much on the outside i think, i can try to adjust the sub box to find the best place in the trunk were i get the most preasure in to the coupé, I have the bass elements and the slotted vent to the back rest in the back seat, Im going to take som pictures of my ongoing work and post them here for you. yea take lots of pics, the suggestions should come flying in, take pics of how your amp settings look, box position in the trunk ect.... its very hard to throw suggestions in the way you need them without seeing them What size power and ground wire are you using, full details please
Gnarkill Posted July 4, 2012 Author Report Posted July 4, 2012 Yesterday i changed the positive and negative cables from the alternator to the battery and the ground wires fron original to 4 AWG. im also going to change the amp cabels to the 4 awg aswell.
Gnarkill Posted July 4, 2012 Author Report Posted July 4, 2012 This is the amp and this is the sub speccs what do you guys think? I run the dual subs on 1ohm from the amp. SUBS RMS Power : 300WMax Power : 900WFrequency response : 28Hz - 200HzSensitivity : 87,5 dB/2,83v/1mFs : 28,4HzRe : 6,87OhmZ : 4Ohm + 4 OhmQms : 6,94Qes : 0,52Qts : 0,48Vas : 31,7LiterMms : 175,2grCms : 0,180mm/NBL : 20,4N/ASd : 353cm2Vd : 0,56LiterXmax : 16,0mmDiameter : 25cm ( AMP Max. power output* into 4 Ω800 WattRMS power output** into 4 Ω350 WattMax. power output* into 2 Ω1300 WattRMS power output** into 2 Ω600 WattRMS power output** into 1 Ω2000 WattRMS power output** into 1 Ω800 WattFrequency response16-200Hz (-3dB)THD< 0,08 % (100 Hz)Signal-to-noise ratio> 100 dBInput sensitivity50 kOhm(s)Dimensions (W x L x D)263 x 48.5 x 210 mmWeight 3,2kg
Riley Evan Houser Posted July 4, 2012 Report Posted July 4, 2012 Here's the way I look at it.. If you're happy with what you have..and it sounds good to YOU. Fuck what anybody else says
