Running two bb2400.1 on 4re sxx d4 used the smd dd the were set fine but I keep blowing the same amp twice this has happened the other amp runs fine. Plese Heeeelllppp!
Voltage drop, bad RCAs, bad ground, bad headunit.
Running your subs at .5 Ohms isn't helping either.
*New vehicle and system coming soon.*
The volts are around 12 when eerily banging on them I have two 300 amp ALTs on it.also 3. batteries Volta are .fine i'm running a audio control epicenter. Andi'm running two amps asst 1 ohm
  • Who's Online   1 Member, 0 Anonymous, 1332 Guests (See full list)
