b-dubs89 Posted August 24, 2012 Report Posted August 24, 2012 its a 93 300 L6, fuel injected.. but ive been thinkin and thinkin im probably gonna end up doin the 4wd conversion in it, and maybe doin a 351W conversion and doin the heads n pistons n everything like yall have been sayin im just wonderin how much it would all cost for a 4wd conversion, axles, tranny, computer, and the bone stock 351.. damn im about to cry just typin all that haha, gotta spend some money to play with the big boys though haha what is this 4wd conversion you speak of . is the truck currently 2wd or are talking about changing the front hubs ?
reg93f150 Posted August 27, 2012 Author Report Posted August 27, 2012 Yeah the truck is currently a 2wd, the 4wd isint a for sure thing but a personal preference more then less so I dont get stuck in wet grass or if someone pees behind my tire haha.. ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
Jessica Posted August 27, 2012 Report Posted August 27, 2012 If you go with a 351w just get a carburated one and skip the computer, you won't need it. That will save you a lot of headache. If you don't want to spend all the money converting to 4wd you could get a limited slip diff. You will have plenty of traction, or spend the money you would have on a 4wd conversion and drop it 2/4 and put a 4 link under the rear. So many possibilities. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
reg93f150 Posted August 27, 2012 Author Report Posted August 27, 2012 yeah that's probably what i will do, i have limited slip in my truck as of right now, it always spins both tires no matter what, never get that 1 wheel peel.. haha but yeah ive been lookin it up, im probably gonna go with the carborator instead of fuel injected to make it easier to get power and what not, so i was thinkin.. im gonna have to end up gettin the engine, transmission, would i have to get new master cylinder and fuel pump and water pumps n what not? this build wont be happening any time soon its a future idea when i get a estimate on how much it would all cost.. the mods i want in it are like old school mods.. like a huge cam, headers, maybe bored out, straight pipe.. if anyone would have an idea on how much it would about cost, or know any shops around the 77520 area code that do stuff like this it would help so much, thank you all. ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
79Bronco Posted August 30, 2012 Report Posted August 30, 2012 Ah the Ford 300. They are truly great motors. You can beat the living piss out of them and they will last forever. Let's clear up some cludder in the thread shall we? Looking for louder? Go with an intake and exhaust. Looking for faster? Change the gears in the rear end. I'm guessing you've got an 8.8 since it's in an F150. Ford stopped producing the 9 inch in the late 80's (86?) Since it's 2wd you've probably got some 3.08, 3.55's or something similar in there. (If you crawl up under the truck and look at the tag stamped on the rear end, it should tell you something like 88308 or 88355. The 88 stands for 8.8, the model number of the rear end, and 308/355 would be the gear ratio. Swap in some 4.10s or 4.56's and you'll be amazed at how much quicker the truck will get up and go. 5.4 Lightning swap - LOL that engine isn't cheap, and the supercharger that sits on top of it isnt cheap either. And judging by the fact that you're even asking this question to begin with means you probably don't have the money, or the mechanical savvy to swap it in yourself. (And no, paying someone to do it isn't cheap). Also FYI, the lightning came supercharged from the factory, so you dont have to save up for a supercharger if you do decide to go this route. Now, if you're absolutely set on a v8 swap, a 351w will do wonders in your truck. There is also a 460, Ford's "Big Bad Dood" of a motor if you're looking for something that weighs a lot and makes even more power. Ford's Hi-po motor back in the day; however, was the 427. All of these v8's would be a good choice for a swap, but the 351w would be best since it would mount right up to your transmission without the need of an adapter. Also, many people will talk down on an m series motor (351m or 400) but don't listen to them. I've had my bronco for 4 years now and it has the 400 in it. It's got 300k+ on it without a rebuild, and since I've gotten it, I've changed the oil maybe 3 times, and I beat the everliving dog piss out of it. Seriously, We're talking 5k rpm bouncing its way through the mud for a good 30 seconds at a time. The motor is quite frankly, a brick shithouse. I've actually tried to break it just so I'd have an excuse to rebuild it, and it just refuses to die. Ford did a great job with the M motors, but as with life, there are always haters. 4wd conversion- no, just no. If you want 4wd, you'll need to get a truck with 4wd. Having seen people personally do a 4wd swap, it is a bigger PITA than you could ever imagine. We're talking about swapping out transmission parts, adding a transfer case, two new driveshafts, a new front axle, new steering setup, new brake setup, and a huge PITA. Did I mention it was a huge PITA? Also, whatever the motor came with, carb or fuel injected, keep it on there. Your post talking about a "huge cam, straight pipe, and bored out" leads me to believe that you wouldn't know how to mess with converting either system to the next, and often times unless you're very savvy as to how the nuances of a motor work, you run into a lot more problems than it's worth. Master cylinder deals with the breaks, not the engine, so no that won't need to be replaced. The water pump is inside of the engine and deals with its cooling system, so no that wont need to be replaced. Summary- Get new gears for the rear end for faster. Get an exhaust for louder Look into a 351w swap for down the road. Source: Parrot Asteroid Smart Processor: Digital Designs X1 Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400 Front stage: Hertz 165xl + HL 70 + HT28 Rear fill: Hertz 165xl Subs: 2 SA-12's 3-way active ftw
b-dubs89 Posted August 30, 2012 Report Posted August 30, 2012 yeah i have to agree , if you want a 4x4 get a 4x4 , but you could still have some fun with your I6 . converting 4 wheel drive is not easy or cost efficient in my opinion , big project .
reg93f150 Posted August 30, 2012 Author Report Posted August 30, 2012 yeah, thanks bronco for all the information and yeah i know the lightning motor is a pretty dime.. haha and yeah ill probably just end up doing the windsor swap, and your sure i can just use my stock transmission that's on my truck right now? damn lol thats crazy, but i mean if i did get that windsor swap it wouldent just be a stock motor going in, id get it bored, cammed etc.. so id have to end up building my transmission to support it im just lookin for about a price how much it would cost though ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
79Bronco Posted September 1, 2012 Report Posted September 1, 2012 I'm almost positive the trans in your truck is the E4OD. A stout little transmission, and with a few hundred bucks thrown at it, maybe a rebuild as well depending on how many miles it has, it should hold up to some decent power from the wheezer. Good luck. Keep us posted. Source: Parrot Asteroid Smart Processor: Digital Designs X1 Amps: Soundstream Ref 4.920 + Soundstream Ref 4.400 + Soundstream DTR 3400 Front stage: Hertz 165xl + HL 70 + HT28 Rear fill: Hertz 165xl Subs: 2 SA-12's 3-way active ftw
reg93f150 Posted September 1, 2012 Author Report Posted September 1, 2012 damn that's badass lol i was thinkin i was gonna have to get another transmission and then build it too.. but yeah im gonna start callin some well known shops around where i live and gettin the quote price of everything when its finished.. i know theyres some badass diesel shops around here well there automotive and diesel repair shops.. but they know they're stuff around cars and trucks for sure.. gonna see what they say about me doin it and how much.. one thing im worried about is me just spinnin my ass off if i get on it, my trucks a long bed with no weight at back they're haha ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
